Lume1-FW3X: Constant Current Buck-Boost & FET Driver with Anduril1/2 + RGB Aux
+1
Lower than the stock driver if possible.
Something is in the works..
But why? 3A is quite fine for this flashlight. The Ti version doesn’t pull any more. It seems to me steps backwards. I understand everyone wants a lot of power in a small package, but it doesn’t make sense if it’s only available for a few seconds. In this case, less = better. I hope that I am not the only one who thinks so and it will not be changed.
Plus, it works great with the 219B.
I agree. 3A constant current means an already hot flashlight, especially with specific LED’s. I would much rather have a way to limit or manage turbo current for longer turbo runs. If it could be user adjustable to suit specific LED setups or turbo runtime management it would be fantastic.
Unpopular opinion: with 6A i say get rid of the FET entirely and make that Turbo. Add more quality of life features with board space.
Hmmmm…
This is the way.
This is the way...
There was some talk months ago about making a regular 21 mm driver based on lume1 design.
Any news about it?
This one can be filed down to 21mm and an e-switch pad will be added in the next version.
I have it! :smiley:
It is a very nice picture! What do you think of performance of lume1 compare with orignal driver?
Is the left image a emisar D4? The driver look different from original, is it a special driver?
Out of curiosity, would it be possible to modify this driver to work with 6V LEDs?
Vout max of TPS63020 is 5.5V.
Hmmm...
It’s the buck-boost IC that this driver uses, hence it cannot drive 6V LEDs.
Would it be reasonably possible to replace TPS63020 with something similar that would offer higher output range? F.e. I don’t know if it would be any good but I see TPS552882-Q1 that is only 2mm² larger and offers much higher in/out voltage range. As well as much higher currents. :wink:
It’s less integrated, requires a few more passive and 2 external N channel mosfet for the buck leg, for example a dual N channel 3.3x3.3mm mosfet.
Last time I looked at this IC I tried using Webench and it doens’t want to design the circuit with 1S li-ion voltage so maybe I missed something in the datasheet.
I see, thanks for your input.
LumeX1 will cover all boost driver needs. That new TI boost IC is really nice
