LumenZilla's 13th Annual Old Lumens Challenge Entry - Modified Light
I’ve been thinking that everything with batteries are potential to become flashlights. It may come handy when blackout and we can use any common household items for illumination device(s).
Image above is for illustration only as I’m currently collecting the materials.
– reserved -
Finally I could find spare time to work with the project.
I have several ideas but this time I start with adding flashlight functionality into a regular remote control. It has batteries, it’s used almost everyday, it has suitable form factor for a handheld light.
I have bunch of spare XPG LEDS, spare optics, and spare driver. If I recall correctly, it’s an AA driver bought from Fasttech some years ago.
I started with disassembling the remote control. It wasn’t difficult task because I’m using a plastic opener tool (that black triangle-ish thing).
Luck is in my side since the remote control is not the thin/slim one. This will give me good chance to insert the optic and the wiring job.
First thing first, I soldered wire from driver to battery contacts to test if the driver working as expected.
Yes it worked!
Then I continued with drilling a hole on the remote control’s body for placing the optic. I’m using a small rotary tool and knife as well.
It took a while to drill the hole.
I forgot charging the rotary tool so I had to stop mid-way and charge it first :duh:
This flashlight need a switch.
I know it would be awesome if I can utilize the existing buttons on the remote control to manipulate the light, but I’m not that smart so I’ll go with mechanical clicky.
Haha, that’s awesome. I’ve been thinking about doing something similar with a non-flashlight electronics device.
You probably know this - those buttons are basically momentary switches so you’d need an eswitch driver to use one for the flashlight functionality (or additional electronics to make a latching circuit).
If your driver’s current draw is low enough you could use a small toggle switch. I don’t know your living situation, but if I did this kind of thing I’d make the switch as discreet as possible and wait until my wife or kids notice. Though they’d probably think I’d gone totally crazy with this hobby at that point.
Thanks for your feedback.
Yes, I’m thinking about using e-switch driver to be able to use existing buttons in the remote control. Discreet switch is something tempting to achieve.
Second part goes below.
I finish it on February 7th, 00.50-ish local time (GMT+7). If it’s not allowed, feel free to disqualify my entry.
Previously I planned to make the button as discreet as possible. BUT nobody will aware if it’s a flashlight :sweat_smile:
I want this flashlight to be useful and can be used by anyone in the house.
I went with clicky switch on the bottom side of the remote controller.
I found 10mm rubber boot and small clicky switch, suitable for my plan.
To hold the switch in place, I used double tape. It also used to attach the orange plastic into the remote controller’s shell.
I found it’s difficult to work with single core wire because it’s springy. So I changed the wiring with better and more flexible cable.
I used kapton tape to mount the emitter (and sinkpad) into the optic.
Moment of truth: reassembling all together. I have tested it before putting the board back and anxious if it will work or not.
It works!
Here’s the top side view.
Here’s the bottom side view.
And it’s DONE!
It looks like normal remote controller (it is!) that you see anywhere.
But it’s not!
Thanks for reading :slight_smile:
Additional Note:
The remote controller is still working. No picture was taken because the TV is in my bedroom and I don’t want to disturb the sleeping queen.
8 Thanks
This is great! Very inspiring for modding ideas. Just about anything can become a flashlight.
Thanks. I already collected some spare parts for the next “make anything into flashlight” project.
Great spot for the button!
Very creative mod LumenZilla. :+1:
