Trying to reduce a light to just a few numbers has its critics, and rightly so. But there is utility in simplicity, at least as a first cut or a way of comparison. So, instead of, for example, reporting the spectral graph of the light output, the CCT and CRI (and maybe R9 and duv) are given as a guide.
I recently learned about ‘throw index’ or max intensity divided by luminous flux in candelas per lumens - I still don’t know how the flashlight beam is really distributed but at least I can intelligently guess whether it’s a super-thrower or a lantern or something in between. Some reviewers like ZeroAir routinely report it along other parameters.
Which brings me to, call it, ‘luminuous capacity’ of a flashlight with a fully charged battery in lumen-hours. Similar to quoting energy content of a battery in Wh at certain loads, the luminous capacity gives the total OFT lumens off one given battery charge, for a given light with a given LED, perhaps at different loads/brightness.
I don’t think it’s a popular measure, but I think I saw it once somewhere before. I find it useful to roughly quantify and compare how much total light a flashlight+battery is able to produce on one charge, more or less independent of its discharge profile. While it is a rough number, and it may vary with light intensity used (lower brightness over longer time may give out more total light than higher discharges lasting shorter, but probably only up to a point) I find it useful to have an idea how much ‘total light’ I’m holding in my hand. I also found it a decent first-cut indicator of driver efficiency, other things being equal.
To calculate it, one needs to find a reliable runtime graph for the flashlight (possibly at different output levels) - lumens vs. hours - and integrate the area(s) under the curve(s). So, as a ‘proof’ of concept I estimated the ‘luminous efficiency’ (maybe there is a better name for it?) for a few 18350 and 18650 lights using published runtime graphs for them:
16340
- Sofirn SC21 (regulated, non-Anduril): ~300 lm•h
- Sofirn SC21 Pro (unregulated, Anduril): ~200 lm•h
14500
- Emisar D3AA: ~350 lm•h
18350
- Sofirn SC13/519A: ~200 lm•h
- Wurkkos TS11S: ~250 lm•h
- Sofirn IF19: ~300 lm•h
- Skillhunt EC200Mini: ~400 lm•h
- Trunite Catapult Mini Pro: ~500 lm•h (High) | ~600 lm•h (Med)?
- Wurkkos FC11C w/18350: ~350 lm•h on High, ~500 lm•h on Low.
18650
- Sofirn D25LR: ~800 lm•h
- Sofirn HS42: ~1000 lm•h (High/Med)
- Sofirn HS21: ~1000 lm•h (on Turbo/High, and higher on Med)
- Wurkkos FC11 (unregulated): ~1000 lm•h (Med)
- Wurkkos FC11C: ~1000 lm•h (Turbo/High) | ~1500 lm•h (Med)
- Zebralight SC64w: ~1200 lm•h
I wonder if such a parameter or comparisons based on it make sense to others and if there are some deep pitfalls in using it that I don’t see.
As mentioned, I treat it as a rough indicator and the precision of the values above are limited (at least +/-10%). The battery and discharge rate also play a role, but, at least to me, this value give me some feel as to how much light I can practically squeeze from a particular flashlight and thus what can be done with it. Roughly.
p.s. This goes right against the simplicity claimed above, would be harder to interpret, and thus it’s probably not a good idea, but I figured I will dot this thought down as well - perhaps taking a square root of lm-h and giving it some fancy name could theoretically be even better as a measure of the ‘total perceived light’ that a flashlight can deliver as it would attempt to take into account brightness perception nonlinearity…
