I posted my first impression of this light in the WYGT thread, but I think it is better to start a dedicated thread about it.
(I repeat that post and add some beamshots at the end)
Got my Lumintop Ant Man today.
First impression: nice but it performs under specs, and they missed some opportunities.
On the best 14500 out there, Vapcell H10, I only get 120lumen/67kcd. On the golden Vapcell only 100 lumen. Maybe a tail spring bypass could boost it a bit but I doubt that even de specs can be met with that. The current on the H10 is only 800mA, sounds like going 14500 causes a voltage-struggle getting the laser going, seems that Lumintop did not make a boost-driver for this one.
The beam is pretty nice, no rings or anything. The tint is typical LEP: 7600K, 63CRI, duv +0.013. Nothing wrong with that for a thrower.
Disappointing to me, the projection lens is only 13.5mm diameter while easily a 16mm lens would have fit. This would have produced 40% more kcd.
The ring is blue GITD stuff.
The phosfor looks like many other LEP’s, it is the back-illuminated type.
The size is a bit larger than a Convoy T2, but it still feels compact to me.
But what I like best about the Ant Man is the design, it is the best looking flashlight that I have ever owned, reminds me of the old Foursevens Quark AA, but nicer!
Now that it is night, here are some beamshots. I compare the Ant Man with my two best 14500 throwers to see if it is in a different league.
Left is a Lumintop GT-micro that I modded with a 1mm2 White Flat, middle is the Ant Man, right is a cheap Cofly zoomie that I heavily modded a couple of years ago with a BLF-A6 direct driver and a dedomed XP-G2 S4 3D. As you can see, the Ant Man is the smallest, but not by that much.
The GT-micro I measured at 125kcd, the Cofly at 56kcd which is very close to the Ant Man (67kcd).
First the Cofly left and the Ant Man right:
The camera did something funny with the colours of the XP-G2 beam (edit: camera was fine, it is a pile of brown Taxodium needles on the grass), but you can see, at 40 meter distance on the grass, that the beams are not very bright (maybe I reduced the brightness of the picture a bit too much, on my new phone it looked brighter and closer to reality) and quite similar in brightness.
Now the GT-micro on the left and the Ant Man on the right:
The Ant Man is rather blown away by the GT-Micro.
And to show that the Ant Man on its own does do a proper job throwing a beam (and to show off the 4.4x optical zoom on my new phone), here is some houses at 100 meter distance. The greenish illumination of the top floor (looks not green in reality) is done by the Ant Man.
So to conclude: the Ant Man does not perform better than my former best 14500 throwers, but I believe if Lumintop had tried harder, they could have achieved that while staying within the size of the Ant Man.
I may do a runtime/output test later, if ChibiM does not beat me to that.
Please post your thoughts of, and experiences with the Ant Man in this thread ![]()
