Set your temp calibration differently you get different results (better or worse)
Use a different battery, FET reacts different
MFG could set a hard turbo drop at 31s just to “pass off” high FL1 results
Bottom line, a full review like you guys give is necessary to determine the usefulness like you say. 30s measurements are basically only useful in determining how regulated the output is. Too many variables and ways to game it.
That 32kcd measurement must have been at turn-on or with basically no step-down yet, otherwise this light is getting D1S throw out of a much smaller reflector.
Yeah, throw was measured at start, and lumens were measured at 30s. This light is not making 48 cd/lm. It’s more like 20 to 25 cd/lm with XP-L HI, or 10 to 12 cd/lm with XP-L HD.
For comparison, the D1 is about 33 cd/lm, and D1S is about 100 cd/lm.
With lights like this which have a burst mode much higher than what they can sustain, it’s probably a good idea to measure the burst and the sustainable levels separately.
I’m sorry if this is a silly question but I’m a modding novice. I want to reflow an LH351D on my FW1A, but will the centering ring cause a problem? I’m not sure if it’s soldered down and will desolder when I heat the MCPCB on my griddle, or if it will stay in place and not be damaged.
The centering ring is just a piece of plastic and it HAS to be removed before the reflow. Otherwise it'll just melt and make a mess. It's not glued or held in place by anything other than the corners of the emitter.
This is the same LED that I dropped in mine on day 2. Process is very easy. Remove bezel, carefully remove reflector and don’t touch the reflective surface, unsolder wires from mcpcb, pull out mcpcb, lift off centering ring, replace LED and since you are this far in pull the driver and install the latest firmware if you have the tools. Just reverse the process and fire it up.
I recommend that you test the LED to mcpcb connection before assembly. This can be done with the diode function on a multimeter or with a current controlled power supply. If you do not have either, a lithium ion cell with less that 10 amps of capability will also test it. I use a 14400 cell when I am not near my power supply. Some LEDs can draw enough with a straight connection to a good cell to damage or cook themselves. But it sucks to get it back together and find out your reflow was not good.
A decent soldering iron is required for soldering on a direct thermal path mcpcb as it will really suck heat away from the iron.
For testing LED/MCPCB, I soldered two alkaline AA batteries together in series with positive and negative leads hanging off. Lights it up nice and bright without any danger of cooking the LED!
Ambient = 37354.6 Lux, CCT = 4009K (Duv 0.0032)
Color Rendering Index (Ra) = 93.3 [ R9 = 77.7 ]
Ambient = 49993.5 Lux, CCT = 3972K (Duv 0.0010)
Color Rendering Index (Ra) = 93.2 [ R9 = 75.4 ]
Needless to say the beam shape is fine if you want throwy but, as expected, a reflector really brings out the worst for the tint. The subset of snobby tint users that don’t care about CRI will want XP-L HI. The snobby and high CRI users will probably want, shaved LH351D maybe? And the less snobby high CRI users will probably go for any half decent LH351D (this is my camp typically).
My switch board came “always on”. Once the tail is tightened down the inner tube and outer body are always making contact causing the light to start ramping right away. I had to clean, re-adjust, and jack with the tail board and ultimately I have a working switch with no retaining ring. Needless to say if the thing gets lightly dropped or tail loosens I will have problems again but that’s an issue for another day.
There’s seemed to be a black retaining ring, in the tail switch, preventing the button cap from dissembling. I think it is new to FW1A compare to FW3A. There are two little notches on opposite sides. Does it just unscrew to remove? I’m having a bit of a difficulty removing it, maybe I just don’t have the right tools. I’m trying to install a Turboglow button cap.
I manage to undo mine with a small set of scissors, was a bit hard at first and had to hunt around the house trying tweezers, pliers, etc till I found something that was a good fit.
