Lumintop GT Mini Copper/Brass Set - 750 lm, 1050m - $69
MSRP: $250 for the set
Sales is as is!
Batteries not included!
NOTE:
I’ll be posting a lot more lights; around 40 more soon. So to save time, I’ll upload actual photos upon request.
The Lumintop GT Mini Copper/Brass edition is a long-range compact thrower flashlight featuring an Osram KW CSLNM1.1G (cool white) LED, Andúril firmware, and a body crafted from heavy copper or brass.
Key Specifications & Features
• Emitter: Osram KW CSLNM1.1G (cool white) LED on a copper DTP MCPCB
• Throw / Intensity: Over 1,050 meters of ANSI throw with an intensity greater than 372,625 cd
• Firmware & UI: Andúril firmware featuring smooth ramping by default, instant access to turbo, discrete 12-mode set options, and a momentary mode
• Body Material: Copper / Brass construction
• Reflector: 43 mm inner diameter, smooth aluminum finish
• Lens: Glass with anti-reflective coating
• Switch: Tactile side switch with a back-lit rubber boot
• Ingress Rating: IP68 (waterproof up to 2 meters)
• Dimensions: Approximately 50 mm head diameter × 132 mm to 133.5 mm length
• Weight: Approximately 400g to 440g (without battery)
Battery & Power
• Battery Support: Operates on a single 18650 Li-ion cell (max length 70mm).
• Note: Protected cells are recommended, and cells are typically not included in the package.
