MSRP: $50
Sale is as is!
Battery not included!
NOTE:
I’ll be posting a lot more lights; around 40 more soon. So to save time, I’ll upload actual photos upon request.
The Lumintop GT Mini v1 is a compact, long-range pocket thrower flashlight powered by an 18650 cell and controlled by Tom E’s open-source NarsilM firmware.
Key Specifications
• Emitter: Cree XP-L HI (available in neutral white or cold white options) on a copper DTP MCPCB
• Max Output: Over 1,200 lumens
• Beam Intensity & Throw: >135,000 cd, delivering an ANSI throw distance over 750 meters
• Driver: 17W, 4.5A FET driver with a low parasitic drain (~27 µA)
• Battery: One button-top 18650 Li-ion cell.
• Reflector: 43 mm ID smooth aluminum finish
• Lens: Glass with anti-reflective coating
• Body Construction: Aluminum with Type III hard-coat anodizing
• Switch: Tactile side switch with a back-lit rubber boot
• Ingress Protection: IP68 (waterproof up to 2 meters underwater)
• Dimensions: 50 mm head diameter × 132 mm length
• Weight: 150g (without batteries)
User Interface & Modes (NarsilM)
• Default UI: Smooth ramping mode (0% to 80%) with instant access to 100% Turbo mode.
• On / Off: Single click of the switch (features mode memory).
• Ramping: Press and hold from ON to change output level; release and press-and-hold again to reverse direction.
• Turbo: 2 quick clicks from ON.
• Moonlight / Ultra-Low: Press and hold from OFF.
• Strobe / SOS / Beacon: 3 clicks from OFF to enter Strobe, then 3 additional clicks to cycle through blinking modes.
• Lock-out / Unlock: 4 clicks from OFF (or loosen tail threads).
• Back-lit Switch Light Control: 5 clicks from OFF.
• Battery Check: 7 clicks from OFF (blinks out voltage, e.g., 3 blinks then 8 blinks for 3.8V).
