Edit: April 2 - This activity is Closed.
Video review of the EDC25 by vestureofblood: An Everyday Carry You Need
Review by zeremifico: Lumintop SD26 photo review - Discount coupon available - disassembly & mod to follow
EDIT: Mar 14: Code for NU30 available via request by posting here
EDIT: FEB. 17: Code for both lights now available, Guaranteed, lowest price, just post here and ask
EDIT: FEB. 16: SD26 code is available; EDC25 to sent when available (due to system glitch)
BOTH CODES WILL BE SENT TO ALL POSTERS IN THIS THREAD THAT ASK FOR CODE AS IT BECOMES AVAILABLE
SD26: http://www.lumintop.com/sd26.html
Main Features:
● Utilizes CREE XP-L HD LED, boasts max 1000Lm output, 10600cd peak beam intensity and 205m far throw distance
● Intelligent Li-ion battery charging circuit, integrated micro USB charging port is water, dust and impact resistant
● Advanced temperature regulation system allows for adjusting output performance according to body temperature
● Lock-out: at Moonlight mode, long press for 8s, the light turns off and flashes indicating lock-out, cut off the power to unlock
● Waterproof in accordance with IPX-8 ( submersible to 2 meters )
● Runs on 1 x 26650 battery or 1 x 18650 with adaptor ( NOT included )
● High strength aerospace aluminum alloy construction with anti-scratching type HAIII military grade hard-anodized finish
● Double-side AR coated tempered lens resists impact and thermal shock, maximizes light transmission up to 99pct
● Reverse polarity protection / memory function / anti-rolling design / dual spring-loaded impact absorption mechanism / tail stand
Output and Runtime:
Turbo: 1000 - 600Lm, 1.66 - 3.33h
High: 530Lm, 4.5h
Mid: 170Lm, 18h
Low: 45Lm, 60h
Moonlight: 1Lm, 45 days
Strobe / SOS / Aviation Signal: 1000Lm
EDC25: http://www.lumintop.com/lumintop-edc25.html
Main Features:
● Uses Cree XP-L V5 LED with a lifespan of 50000 hours, max 1000 Lumens
● Hidden Micro USB charging port, red and green indicators display charging process
● Easily change between Tactical and Outdoor settings
● 6 variable modes: Low - Mid - High - Turbo - Strobe - Moonlight
● Tactical tail switch with momentary-on function
● Side switch to select outputs under Outdoor mode, only capable of mode changing under Tactical mode
● Low-voltage indicator is built into side switch, it flicker faster with lower power
● Automatically changes to LOW mode when remaining battery is too low, and gear cannot be changed
● Digitally regulated output maintains non-flickering constant brightness
● Optimized ultra-precise reflector offers 205m far reaching beam
● Double-side AR coated tempered window resists impact and thermal shock, maximizes light transmission up to 99pct
● Powered by 1 x 18650 or 2 x CR123A battery ( not included )
● Memory function / reverse polarity protection / stainless steel clip / anti-rolling and anti-skidding design
Note: flashlight can not be charged when using CR123A batteries
