Hi guys,
We all want a real deal for our money, right? Here is one, the Lumintop TD16
MSRP: $ 71.01 Product link: http://www.gearbest.com/led-flashlights/pp_261758.html?wid=21
This deal: $ 34.99 (limited stocks, shipping will start from 5 to 10 business days hopefully, as stocks arrive)
*Coupon for the Deal price will be sent via pm to all who post in this thread *as ‘Priority Buyers’.
LUMINTOP TD16 is the upgraded edition of the popular tactical flashlight TD15X, it has the classic stylish design, and you will be marveled at its newly designed full-size front side button switch and consistent silo integrated structure. Designed for convenience and ease-of-use, the push-button tactical tail switch allows momentary-on, while a simple press on the big side switch provides one-handed operation and easy access to 6 light modes (low - mid - high - strobe - flash - slow flash), which cover from daily use to outdoor and professional use all you need. Not only that but the intelligent memory function will memory the last mode before you turn off the light. Its consistent silo integrated structure ensures the best heat dissipation structure cylinder head multi-channel heatsink cooling effect. Dual spring-loaded impact absorption mechanism with reverse polarity protection design, all these make TD16 become the best weapon flashlight.
Main Features:
● Utilizes CREE XM-L2 U2 LED with max 1000Lm output
● Three brightness (high - mid - low) and three flash modes ( strobe - flash - slow flash )
● Waterproof in accordance with IPX-8 (submersible to 2 meters)
● Newly designed full-size front side button switch and consistent silo integrated structure
● Tail cap switch and side switch for convenient use
● Intelligent memory function / reverse polarity protection
General:
Brand: Lumintop
Model: TD16
Lamp Beads: Cree XM-L2 U2
Beads Number: 1
Luminous Flux: 1000Lm
Luminous Intensity: 24025cd
Switch Type: Clicky
Switch Location: Side Switch,Tail Cap
Feature: Stainless Steel Bezel,Pocket Clip,Lanyard,Integrated Heat Dissipation Design
Function: Camping,Hiking,Walking,Night Riding,Household Use,EDC
Battery Type: 18650,CR123A
Battery Quantity: 1 x 18650 / 2 x CR123A battery (not included)
Mode: 5(High; Mid; Low; Strobe; Flash; Slow Flash)
Mode Memory: Yes
Waterproof Standard: IPX-8 Standard Waterproof (Underwater 2m)
Product Details:
Power Source: Battery
Reflector: Aluminum Smooth Reflector
Lens: Toughened Ultra-clear Double Glass Lens with Anti-reflective Coating
Impact Resistance: 1.5M
Beam Distance: 300-400m
Flashlight Processing Technology: Aerospace Grade Aluminum Body with Anti Scratching Type III Hard Anodization
Body Material: Aerospace-grade Aluminum Alloy
Available Light Color: Cool White
Available color: Black
Runtime:
High Mode: 1.5h
Mid Mode: 6h
Low Mode: 40h
Strobe Mode: 3h
Dimension and Weight:
Product weight: 0.158 kg
Package weight: 0.404 kg
Product size (L x W x H): 15.40 x 3.80 x 3.80 cm / 6.06 x 1.5 x 1.5 inches
Package size (L x W x H): 22.20 x 12.10 x 4.50 cm / 8.74 x 4.76 x 1.77 inches
Package Contents:
1 x Lumintop TD16 LED Flashlight
2 x O-ring
1 x Lanyard
1 x Holster
1 x Tail Cap
