Lumintop Thanos 23 Dual Source Powerful Flashlight Coming Out Now
Lumintop Thanos 23 Key Features
Choice of Floodlight, Spotlight, and Combined beam patterns for a power of up to 27000 lumens
Maximum range Floodlight (500m), Spotlight (600m), Combined (700m)
Portable form factor – 153mm x 68mm x 51mm (length x head diameter x body diameter). Weight of 550g (no cells)
Large LCD display on tail cap showing power/voltage/amps etc, with button to cycle information
8 x Cree XHP50.2 and 1 x Luminus SFT40 LEDs
Multiple protections, over discharged, charge, thermal
Powered by 3 x 21700 batteries (button top cells required)
Supports rapid charging and Quick Charge (QC) & Power Delivery (PD) protocols for higher voltage/amps
Power bank with Type C and A ports available
Backlit large side switch with simple UI with shortcuts and lock-out function
IP68 Water resistant, 2 meters water submersion, 1 metre drop tested, dustproof
Quality anodized aluminum body with hard coating, and heat treated glass cover
1/4” Tripod thread
With 10% discount now
Do you like Dual Source flashlight?
