Does anyone happen to know off hand where to get a quality replacement tail switch for the Lumintop Tool. The copper version.
Mine has started to fail. It will turn on fine, but sometimes takes 2-6 half presses to switch into Medium.
Thanks!
Thanks!
Take it apart .clean it …visual inspect and reassemble …Voila it’s fixed !
This should be a replacement part. http://kaidomain.com/p/S023998.9mm-Dia\_-x-18_2mm-H-DIY-LED-Flashlight-Clicky-Switch-5-pcs
Thank you! I’ll try giving it a clean…but also order some extras!
The one sold on Kaidomain is actually longer. So it won’t fit. I had a similar problem but could not find a replacement.
Well that is frustrating…Maybe if I contact Lumintop directly.
Support@lumintop.com the send you a replacement for some Bucks.
