Well, the deal is over but this infomation is still interesting as regards this flashlight.
The linkster in me says: "Don't forget to read this link." #comment-86109
I am also The Cut and Paste King. The Master Mover of Much Material and I also found this for those wanting to hear the other side of the story regarding this particular light. Again it's a quote from an individual on a DX discussion about the MXDL 3W Flashlight . To give him credit for this his user name is brjbrj.
Contrary to the reviewer who caused a stir (and doubless a lot of sales of this light, including myself) by claiming this item accepts pills from P60 modules, I have to disagree, at least to the flat assertion.
On all the P60 pills I have, the threading does not continue all the way to the bottom of the pill. The threading is only on the top part, so it can screw into the original reflector.
So, when you unscrew the pill from the reflector, and try to thread it into the back of the MXDL head, you can only get it threaded about halfway in. Because the threading stops. If the threading continued, yes, it seems like it would work. The threading is compatible until it just runs out.
If you ALREADY have a P60 pill where the threading is completely from top to bottom of the pill, yes I think it would work. And if you do, please POST HERE which item has such a pill. The only one I know of which at least had such a pill, was DX's MC-E drop-in. I don't know if this is the case anymore with that item, and it's irrelevant to me because DX hasn't dropped the price of that drop-in, and it's at a ridiculous price considering both advancements in LED's and the fact that the pill itself is reportedly underdriven.
I suppose if you filed down the unthreaded part of a partly-threaded P60 pill, it might work. I'm not willing to put that kind of effort into such a project right now.
My impressions of this MXDL 3W light: very bad.
Let's start with the LED itself. It is purple-ish/blue-ish and NOT bright, considering it's drawing 3 watts! And it does draw 3 watts (I measured it). But current draw does not necessarily equate to light output! It's output, not input which counts! The LED is a gold dot which seems very cheap, and I've never seen before. 3 watts means your battery won't last long either. On the other side of the spectrum, I have an XM-L drop-in which pulls 3.0 watts (.75 amps at 4.1 volts) on Medium, and has output comparable to an XP-G on high. I'm not comparing cost, but just how much output can vary, and how current draw should not imply ouput. They're almost advertising how inefficient it is.
Now for the body. Also very poor quality and feel. Worst for me, the light was larger than expected. They could've made it smaller. I could almost feel the sweatshop environment in the finish of my 'milky white' version, and felt guilty for buying it.
This flashlight convinced me to stop bottomfeeding. On the internet you can find photos of F*nix's factory in China, as well as photos of other Chinese factories which are frighteningly more primitive (sweatshops). I'm not saying I'm going to buy a F*nix, but I am saying I'm going to stop buying flashlights which are obviously aimed at squeezing every criterion to make something for the absolute least amount of money possible.
Considering I bought this specifically to mod it, and then couldn't mod it with the ease I expected, it was money completely wasted.
If you want a keychain flashlight, there are much better options for not much more money. And make sure you get something with a genuine Cree emitter if you don't want to risk wasting your money.
I also figured out that you need to feel good about your keychain flashlight, because you'll be carrying it everywhere. So if every time you pick up your keys and see it, you feel negative sentiments toward the flashlight, it's not worth it. However if you feel good about the flashlight, it's much nicer. To me, that meant getting the 4s*vens Quark Mini CR2 (Cree XP-G emitter), although it costs 6 times as much as this. However it is more than 6 times better. For about 1/3 to 1/2 less there is the iTP EOS; they make a CR123 version currently with a Cree XP-E (less bright than an XP-G but still good). There are plenty of good CR123 Cree lights on DX but not many CR2's, and those which are are often not any smaller than CR123 versions. I'm just saying there are other options. None this cheap, but if it's money wasted, you saved no money.
My impression is that this light would only impress someone who had never seen or owned an LED flashlight, or at least a 1-LED flashlight. I'm baffled by the positive reviews. If you know what a decent LED light is, or have several LED lights and know rubbish from something good, despite the price, this flashlight is not for you.
If for a gift, only for people who wouldn't know a good flashlight from bad under any circumstance--but then, why would you be giving such a person a light which runs on cr123a's.
