Brightness 600 lm
Working Voltage 3.6~4.5 V
Circuitry 1800 mA
Number of Modes 5
Mode Arrangement Hi > Mid > Lo > Fast strobe > SOS
Switch Type Reverse clicky
Seems to have SS bezel, a good? clip and also includes lanyard… interesting
Which btw is not worth getting! The ordinal N-light ST50 appeared to be a solid 5 mode current regulated driver that could take 2xrcr123’s with no pwm, then they moved to a modified group set and after that a pwm regulated driver that had numerous issues and such (Flickering, unreliable mode switching, etc). I’d recommend staying away from one unless you get it for an extremely cheap price and use it as a host (Like under $25) with the expectation of modding.
In that way the clone might actually be better since you’ve got a standard switch and it might even have a better driver! Granted missing the mode switching, but that doesn’t work well regardless; mine only pulls about .8-.9amps and has a terrible green tint that it gives to the LED. Not worth it despite it’s beefy pill (Planning a 5 mode qlight at this point; possibly modded to pump out more Amps but I don’t think it’s really worth the trade off far as battery life, lumens epically with the OTF losses from the reflector).
