SKILHUNT E3A
LH351B 100 Lumens Mini LED Keychain Light EDC Flashlight
with AAA Battery for Camping Cycling Fishing Lamp
CLICK TO BUY IT NOW Code: MF55496
my deal: $8.99 $15.99 -44%
-> please post in this thread when you have ordered!
Specification:
LED: LH351B
Max output: ANSI 100 Lumens
Max runtime: 100 minutes
Max beam distance: 37 meters
Max peak beam intensity: 350cd
Waterproof: IPX-8
Impact resistant: 1 Meter
Battery: Uses 1xAAA 1.5V Alkaline , 1xAAA 1.2V Ni-MH or 1xAAA 1.5V Lithuim
Rated Range: 0.8V ~ 2V
Color: Blue, red, black, grey
Dimension:
Length 59.5 mm / 2.34 inch
Head diameter 14.0 mm / 0.59 inch
Weight: 7.5 g / 0.26 oz (without battery)
Operation:
Battery installation: Insert the battery positive pole toward the light head, otherwise it will not work.
When the light turning on, the beam is directed away from the eyes.
Take out the battery if you are storing the flashlight for a lont period of time to prevent the battery from leaking.
Flashlight turning on/off:
Fully tighten the tube/tail to turn the light on.
Twist the tube/tail to turn off the light.
Features:
Powered by a convenient and widely available single AAA battery producing an output of 100 lumens.
Made by durable aluminum
Extremely easy carry: Barely know it is there with its lightweight and small size.
Waterproof to IPX-8 Standard
TIR optic lens producing a soft and balanced beam for comfortable use.
Package included:
1 x Mini Keychain Flshlight
1 x AAA battery
1 x Manual
4 x Waterproof ring
