SKILHUNT M300
XHP35 HI/HD 2000LM High Power LED EDC Flashlight
USB Rechargeable IPX8 293m Mini Torch Magnetic Tent Light
CLICK TO BUY IT NOW Code: MF55651
my deal: $45.95 $69.99 -34%
-> please post in this thread when you have ordered!
Features
1.Super bright & latest CREE XHP35 LED, Max 2000 lumens. High-Performance, High-Efficiency and energy conservation.
2.New U.D.O.C Reflector. Increased reflectivity over 10%., Efficiency reflection, perfect beamshot, excellent structure and temperature resistance.
3.Rugged indestructible aluminum body with anti-scratching type III hard anodization
4.Multi-level dissipating heat designand new copper starboard, excellent heat dissipation. Flashlight head integrated construction, high thermal conductivity.
5.Side switch button to transferring mode, user-friendly interface to adjust output.
6.Two mode groups plus editable brightness, more use options for choose.
7.Wide input range provides more choices of batteries. High efficiency driver circuit, no visible flash in any mode.
8.Automatic memory function, remember last used setting and can be preset to specific output mode for instant access.
9.Intelligent temperature control technology for flashlight stable and safe use.
10.Reverse polarity protection, to protect from improper battery installation.
11.When turn off, hold press button to activate lockout function. Avoid light turn on by unexpected.
12.When light lockout, location indicator will flash, easy get the light in dark.
13.Magnetic tail, can be used in many special occasions, use as candle light, etc.
LED: CREE XHP35 HD / HI
Max output:
HD: ANSI 2000 Lumens
HI: ANSI 1700 Lumens
Max runtime: 30 days
Max beam distance: HD: 219 meters HI: 293 meters
Max peak beam intensity: HD: 11500 cd HI: 21500 cd
Waterproof: IPX-8
Impact resistant: 1 Meter
Battery: 1×18650 , 2 × CR123A
Rated Range: 2.7V ~ 8.4V
Dimension:
Length 111 mm / 4.37 inch
Head diameter 28 mm / 1.19 inch
Body diameter 23 mm / 0.9 inch
Weight: 72.5 g / 2.56 oz (without battery)
Accessories: User manual,Spare O-rings,Lanyard,Clip, Magnetic Charging Cable .
