Maeerxu flashlight Father's Day 46% off
The last two days of the 6.18 promotion.
XT3 Titanium original price$ 86.5 discount price $61
DF03 brass Original price $48 Discount price $40
DF01-Titanium original price $95 discount price$ 61
MT3-Titanium Original price $111 Discount price $74
DF01–18650-AL Original price $60 Discount price $40
DF03-14500-Brass Original price $48 Discount price $40
DF03-14500-Copper Original price $60 Discount price $46
Store:https://www.maeerxu.net/
Aliexpress:https://www.aliexpress.com/store/1100390843
Can I make two suggestions for you guys??
Make more copper lights! The only copper you have is a 14500.
And the UI is a little bit on the complex side. I understand the features and differential but perhaps a e-switch and Anduril would make things easier for us!!
Otherwise you have some beautiful lights!
Cheers
Have a look here maeerxu-DF01-Red Copper Flashlight-18650-SST20 - maeerxu - you can get SST20 or 519A with 18650 battery. Keep in mind it’s a heavy flashlight as there’s a lot of copper- with very thick sidewalls on the body.
I have it. Gorgeous light.
Beautiful looking light but they’re out of stock. Why aren’t the specs listed?
These lights are not mass produced. Thye build a certain amount , sell them out, then move on to another model.
Ok. But who sells lights without providing the specs?
ZebraLight? :slight_smile:
Don’t get me wrong, I like ZLs, but they often don’t provide lumen numbers until months later.
Beautiful indeed! Too bad they don’t have it stock anymore. It’s not even listed on aliexpress where I looked at first.
There are specs somewhere on their site. There’s a bit more info on the aluminium DF01 page Maeerxu DF01-AL-18650 Four-lamp high lumen flashlight - maeerxu like max 4000 lumens and the UI flow chart. I have seen output levels for each mode with times somewhere too. @AnnyLi should be able to post them.
I’ve got the copper DF01 18650 with the Nichia 519A. The body itself is every bit as impressive as it looks in their pictures- very well made. The UI takes a bit of getting used to as you need to do very quick half presses to change modes- otherwise you’re basically doing a power off/ on and end up back at the start. The flowing RGB LED’s are impressive - if you like that sort of thing.
I’ve got mine set up so the custom first setting comes on red and then it goes to white light with stepless intensity control. You can also leave the first custom setting empty and have stepped output control.
The only negative point I’ve found is the heat transfer to the copper body isn’t as good as I thought it would be. On the high set the output thermal control will step straight down to 20% output, but the body still feels cool. You’re better off not quite going up to the highest level (say stay at ~70%) and then it will stay on that level for a lot longer. I’m going to try some heatsink compound on the pill to see if that improves things.
Anduril may appear in the future
But it’s a very long process.
The current UI, too, is very interesting, and the main light can be defined to any brightness you want.
There are seven colors of AUX, the flowing AUX, for the first time in a flashlight.
DF03 Brass DF03 copper
This is a mass-produced product from our own factory.
It is always in stock.
Which one you are referring to is out of stock
DF01 Brass
DF01 Red Copper.
I keep looking at listing but it’s never in stock
The DF01 Copper! I’ll definitely get one if it becomes available.
I will consider it with Anduril UI.
The XT3 Ti and DF01 copper looks good.
The DF01 18650 Brass machining looks also good.
DF01-18650-Brass It was out of stock a long time ago.
Now it is DF01-18350-brass
DF01-Copper-18650
There is a SST20 5000K configuration in stock in the US if you want to buy it.
You can PM me.
Price $65 + shipping in the US
Would friends like it if it was changed to the 21700 version?
