The morning sun when it's in your face really shows your age,
But that don't worry me none in my eyes you're everything.
Rusty Joe (Thank You), I got Maggie today and I just want to show a few shots of the before. This may be the most ad-lib thread I have done, so bear with me. By showing the before, I am not saying anything bad about Joe at all. Maggie was a working girl, kind of like a waitress or barmaid. It just means she had an honest life and an honest job, just like Joe.
I think Maggie was a little shocked when I took her out of the box. After all, she went North and ended up in the hands of a Yankee. It would make any Southern girl shudder a little and the first thing she gets, is a tear down and a bath!
Well, it's all for the cause.
I think I can say that Maggie will have the Ano stripped and she will be getting a new coating, yet to be determined.
It looks as though Maggie has some Acid Reflux going on here, but I think some Baking Soda and water will help calm down her insides.
Back when I had a real job (in manufacturing), I was known as Dr. J. If there was a problem, just call Dr. J and the problem was solved.
Well, this may just have Dr. J written all over it.
I will be cleaning all of the acid residue first, with Baking Soda and wire brushes. Then I can clean out the bore of the body with the brake hone. It looks like I need to use the dremel to cut a clean step back in the tail cap, for the spring seat and I will have to also try to cut out all of the damage in the bottom of the tail cap.
Then I will strip part or all of the light and go from there. I imagine the bezel will either end up being crenelated or at least flattened, to clear up the dings. The body may warrant some polished rings in the damaged areas. Most likely, the inside of the tail cap and inside the body will be coated with epoxy, once they are stripped, to seal them up.
I will probably mod Maggie into an LED, but it's not definite yet. I long to do "one more hotwire", just for old times sake. I will have to think on that. I already have bi-pin sockets........ Hmmmmmm.......
That's all for now, I will keep up with progress as it comes. (and I said I wasn't going to do any big mods in the hot part of the year!), well Maggie is a special case.
Today I decided to do a little stripping on Maggie. Removing some of the Ano and some of the battery corrosion, or at least attempting to. I got out the commercial strength Greased Lightning and went to work. It took over an hour on some of the parts, but It did get them cleaned up.
I only stripped part of the head and part of the tail end. When it's together, it looks fairly even as far as the same amount of bare metal at both ends. Once it's polished, it will look much better. I will do some cosmetic polished rings in a couple of places as well.
I am not going to remove all of the scars. Maggie has a history and I don't want to remove all of it.
I did not touch the knurling. I have something special to cover that with. I'm thinking Turk's Head there.
OH, I might even do a little dress up on the tailcap, with a Copper round inlaid into it. I have been thinking of using Copper, Brass, Sterling Silver and Cabochons for big buttons on tail cap switches this fall, so I might just experiment with fitting an insert in this one.
EDIT: Added a couple more shots.
I did get a start on the body rings.
And.......
If anyone is interested, when I have to mark something that is curved (like a Maglite head), I just hold a pencil to a ruler and turn the part, to make a line around it.
I am doing that, to be able to tape off a line on the tapered part of the head, to cut a ring around it. I have several layers of tape, with a thin area as the guide. I will attempt to use my files to cut a ring here. I haven't tried it on a tapered surface yet, so we will see.
That's all for today - Tuesday, 7-10-12
