The owner of a bike shop I frequent is aware of my addiction to lumens and let me teardown one of the display units of a Magicshine MJ-890, possibly to mod. I forgot to get snaps of the housing and the optic it uses, but the outer diameter is >20mm since it didn't want to drop into my Convoy S2.
I'm not sure what LED is on it...tried identifying it by the looks of the substrate, but it didn't match any of the hits from the reference thread! It looks to be XP-* size though.
PCB layout. Here is the datasheet for the MH4057* charging circuit (Mirror). CC/CV with 400mA max current. The driver chip has no markings on it.
Battery and USB port. Specs say a 1500mAh LiPoly. I assume these are 2x 750mAh in parallel.
R0200 is the current limiting resistor…a R0100 should kick it up quite a bit
Q1 appears to be a FET
oh…see C1, pencil lead mod it or solder a 0805 330K ohm resistor across it, disable the next mode memory and have it reset back to default in 5-10 seconds so you can bypass the strobe mode
Thanks for the info everybody. I’m keeping an eye on this one. QX7137 seems to have a much lower sense voltage than some of the other QXMD buck controllers: 100mV instead of 200mV or 250mV.
