Manafont P60 reflector source?
With manafont currently closed for change in management is there another source that sells the same p60 reflectors?
I'm looking to get two of the SMO (SKU: 6047) and about six of the OP (SKU: 5734). Really want to use those, but can't wait for Manafomt to reopen.
Have you looked at Fasttech’s? Good prices and good reviews on these.
http://www.fasttech.com/products/0/10001275/1224002-aluminum-orange-peel-reflector-empty-drop-in-modu
http://www.fasttech.com/products/0/10002206/1164600-empty-aluminum-drop-in-module-wbrass-pill
http://www.fasttech.com/products/0/10002800/1208511-empty-aluminum-orange-peel-drop-in-module-for-cree
I have, I've also seen the good prices and reviews on them. They will probably be my fallback if I can't find the Manafont style.
Those FT reflectors that fit the XM-L have a flat ring at the bottom of the reflector, and on the emitter side have a wide ring around the opening for the LED. I got a similar reflector from IS. With my rusty soldering skills, the wide ring can short the solder blobs before being fully screwed down. The MF reflector tapers fully down to the LED which I prefer, and has much more clearance on the emitter side.
I fixed that IS reflector with a dremel, but it still has that ugly ring and I'm not that fond of the dremel.
I see the problem.
Fasttech’s sku 1208511 does have insulator ring though, it works quite well preventing short as long as the solder doesn’t blob too much.
You can also pair with this centering ring to help prevent short.
https://www.fasttech.com/p/1182004
I never bought from other seller than MF and FT for these, so can’t help you on sourcing from other places.
Looks like I will be using the fasttech drop-ins after all. I see a lot of dremeling in my future. By the time I'm finished my rusty soldering skills should be a little more polished.
Unless someone has another suggestion I'll be ordering 6 of the $1.99 Fasttech Orange Peel empties when I get off work tonight.
What about these :wink:
I thought they have opened again…
No problem. I though the same thing earlier in the week, even started a thread about it until I realized I was wrong.
