Manafont Ultrafire Cree T6 3-Mode Memory P60 LED Drop-in Module (4.2V max) = $16.21 High>Med>Low no disco..
Just got it in the mail today. Man, now I see what all the buzz was about. Dropped it in an L2 and then into an L2P...dis iz da bomb.. Blindingly Bright White... what a bad MoFo.. gonna get another one for sure
I purchased half a dozen of those drop ins from Manafont they are a great deal. Make sure you get a accurate amperage measurement because I have seen this drop in pull well over 4 amps.
Test the amperage draw with a battery fresh out of the charger and make sure it isn't over 4 amps on high if it does you might want to run it on medium for a while before you go to high mode so you don't damage the emitter or driver.
They are great drop-ins for $16, especially since they have no strobe modes. Perfect bulb to drop into an L2x or other host. Glad you like it, welcome to the world of budget brightness!
It's been around for a while this drop-in, but it is fantastic. I'll go out on a limb and say that this is the best budget P60 drop-in around.
Amazing output, flawless tint, well spaced modes, emitter driven hard on high (good and bad!) and in my findings the driver is actually pretty decent when it comes to regulation. Which shocked me to be honest:
If only it had a higher PWM on mid and low... would even pay 20 for that. Some day we will get a seller/manufacturer to mass produce Tido specials. 25 modes free programmable in 4 slots... maybe it is time for a selfish PM. ;-)
I've got about a dozen of these (sku 5720) and every single one pulls over 3.5 amps and about half of them pull over 4. Like E said; be careful on high, they're direct drive on high so . . . no IMRs for sure.
And . . . like Troop said; this drop-in turns any P60 host into a blazing, high performance flashlight. Just make sure the tail cap switch can handle all that juice and my experience has been that wrapping helps a little. More important is a host with some mass around the base of the pill or some other thermal pathway to your hand to wick away the heat.
A better solution is just use high for short periods. I've measured the exterior of a wrapped L2P approaching 155 degrees so, not a give-away light to a non-flashaholic.
After reading Foy's post above, I just had to cofirm.... so I went out to the garage and snagged a couple lengths of heavy copper wire.
Sure enough, instead of the original 2.8 amps I got in my original post with the Harbor Freight DMM leads, the heavy copper gave me 3.78 amps on a TrustFire Flame 3000.... mUHoohhahahahahhaha !!!!
Play with fire guys, but just don't get burned...LOL
Now, what do I do for decent leads on this DMM? Guess I'll make some when I get a chance.
I would be very happy if this was really the case with the dropin. I have one, bought in the manafont promotion a year ago.
I'm very skeptical of that almost linear up to 55min mark output. How it was made anyway? Looks liek it employs almost a buck boost driver to have such a performance which is higly unlikely.
I would actually expect a graph curvature similar to this one without taking even heating in account.
Was the measurement data really that way or is it a rough estimate? Looks better than many commerical high dollar flashlight drivers ar capable of.
I still don't understand, looks pricey, is not even with CC, what driver use any pic? You describe it as magic all that looks weird for me, that driver is not available anywhere?
