Manker T01 "II"
For anyone curious about what the difference is between the old Manker T01 vs the newer Manker T01 "II" and product warranty, I received the following response from Manker:
Thanks for your msg.
1) T01 II is with a stainless steel bezel on the head. but T01 is not.
2) T01 II is with a lanyard hole on the tailcap. but T01 is not. so you can carry it easy &safety to anywhere as EDC gear.
3) T01 II are compatible with AA battery and unprotected flat-top or button-top 14500 battery. but T01 I is power by only AA or unprotected button-top 14500 battery. so you can use more types 14500 battery power to more high lumen output
Attachment is the photo for your reference.
If you order the items from any authorized dealers, Mankerlight will keep the 5 year warranty.
If you have any after-sales in one month after you received the parcel, you can contact us.
After the first month, you need to contact Mankerlight ( info "at " mankerlight " d t" com) directly.
Kind Regards
Alan Gan
Here are comparison Images that somehow I can’t attach to my original post.
So left is v2?
Edited for new information…
Crenelated bezel is V1 non crenelated bezel is V2
V2 you cannot easily access the led/driver because the steel ring is press fit screwed on, on V1 you can because it is screwed on.
I like V1 better… wish they made a 2AA version of it.
Do you have the V2 to confirm that? Still looks like a threaded bezel to me. It looks like the press fit ring is added to the bezel.
Yup.
I have V1, I recall reading that for the V2, maybe someone with a V2 can confirm
Has that same seam at the bezel as the V1. Looks like all they did was not machine the crenelations in the bezel, pressed in a stainless ring. Might actually work better for waterproofing. Looks like the only difference is a longer tail cap to machine the lanyard ring.
This is the V2 closeup of the head, I think it is uni body…
It very well may be.
I think we need to be careful to not make statements based on speculation and presenting them as facts as alot of people will base their purchase decision on the things that are stated in this forum.
Based on my research, and confirmation from Manker via email, the front stainless bezel unscrews and is not glued. This should allow equally good access to the LED as possible in V1.
http://www.wii.tw/~fogerdis/viewthread.php?tid=56770
Sweet! Though I can’t see myself needing to mod them. The driver is potted. (To me that’s a good thing.) The LED should be fine for a long time. Is it me seeing this or is there only half a star?
Is nice to know that it is not press fit, will edit post to reflect that…
Yes it’s a proprietary half circle design, but you can probably fit other mcpcb’s with a little filing here and there…
Yes, I was really happy to see this. I was trying to find a place to buy the original one and it was very difficult to find. After some research, looks like the T01 V2 has the potential to be an equally good light with better battery compatibility.
I actually went ahead and ordered one to be modded with a Nichia 219C 4000K. I will lose some throw as a result, but will be much happier having the warmer CCT and high CRI.
I hear the NW HI is already really good, but still nice to be able to open the light once LED tech advances so you can still upgrade the light.
:slight_smile:
And it looks like you were correct about the head being one piece
Please share with us on how you mod the light when you get it. I am curious to know how you would make a full star fit for future reference.
I don’t think modding the light will be any different than the previous model:
https://budgetlightforum.com/t/-/36274
I don’t plan on changing the star, just remove the existing LED and reflowing the 219C.
I’ll keep you posted nonetheless.
Been lurking for a while. Felt obligated to post.
https://budgetlightforum.com/t/-/40074
TheDude, thanks for sharing this. Interesting to see how 1 person had success modding with 219C , and the other didn’t on lower modes.
Fingers crossed it works for me. Will keep the thread updated once done.
