There are some good primers online too. Google Soldering Tips
Here is one for starters
I don’t have a technicians solder station, just a decent Weller 25 Watt plug in iron similar to the first one on that page. Avoid one of those guns at all costs. They are junk, at least all the ones I have seen are. The 60 Watt iron in your OP is way too much for fine electronics work. 15-25 Watts should be more than enough. Simple irons like these are horses for courses. They are cheap enough to get a couple.
A station is no doubt better but I can’t justify the cost for something I only use occasionally, and I have learned to make my iron work for me. Mostly it gets used soldering cables and leads for my and my churches sound systems. 35 years as a musician and repairing leads makes a lot of experience soldering. Of course, nothing like a full time techie would have. I have found with leads and cables at least, a slightly hotter iron is better than one that isn’t hot enough. You just have to work faster not to overheat things.
A good tip is to practice. Don’t be afraid to heat up your iron and practice on junk circuits, components and bits of wire. It is a good way to get a feel for how soldering works.
The next tip is keep your job and tools clean. Especially your iron tip. If things get dirty you won’t have a good time with it. A paper kitchen towel, folded into a pad a moistened with tap water works fine for tip cleaning. You can buy abrasive paper, brilo pads and small wire brushes for cleaning copper parts. Bakers soldering fluid for big jobs. It is acid based so not for delicate electronics. Get a few sizes of resin cored solder, it makes things easy when you have the right stuff.
If you miss the flow and the joint doesn’t take, clean everything before you try again. The resin will deposit on the job and tip and have to be removed to get a good joint.
Make sure you apply enough heat to the job to make the solder flow nicely, but no more than you need. Thats where the practice is important. You develop a feel for that.
Wear safety glasses if you don’t wear specs. Hot solder spatter in your eyes is NOT fun, or flying bits of wire from your side cutters.
On that subject, I almost rate a decent pair of cutters higher than a good iron. A quality pair will last a lifetime, cheap ones will notch up and not cut well. My all time favourites were a pair of E.A. Berg’s I picked up secondhand. Old school made in Sweden. They have been cutting guitar strings for more than 20 years without a notch in sight. I don’t know of any better quality made today, Knipex may be close but aren’t cheap new. Anyone have a favourite brand?
You might get lucky scouting secondhand shops for irons and stations, I have seen them quite often. Another option is a good portable butane gas powered iron. I have a couple that travel with me in my repair kit. They are variable temp and come in very handy, but you have to be aware of the heat exhaust.
Don’t breathe the flux fumes, they are not good for you.
Have fun, enjoy your new hobby.
