Matress toppers
I was in the process of getting a new bed. I got baited into buying a Zinus memory foam bed for $100 during black friday but that has tons of concerns and questionable quality so I’m returning that. Memory foam in general seems to be a really hit and miss. The cost of a full latex bed is not option right now. I’m a long time springy bed user. Just couple notches above laying on a bare floor.
The next best thing besides getting another bed. Is getting a topper. I’ve had cheaper memory foam toppers in the past. Is paying for the premium for a natural latex topper worth the cost?
I was going to get this brand. https://www.amazon.com/Green-Natural-Latex-Mattress-Topper/dp/B00UYGAH4O/
Hmm…
I’ve never had a natural latex mattress or topper.
I have this memory foam mattress, which is way too firm for me:
https://www.amazon.com/dp/B09Y1WGXWP
I also have two of each of these, which makes my bed very comfortable:
https://www.amazon.com/dp/B08897WC74
https://www.amazon.com/dp/B09XQW7S1N
Good luck in your search!
Having a comfortable bed is crucial.
An excellent website with information about mattresses and toppers is this one, though they don’t cover every brand:
Mattresses have gone downhill like most things. I really dont like foam mattresses. Some are comfortable but they cost $50 to make and they are sold for thousands.
At least when a spring mattress costs $5000 you know at least there is a couple thousand in materials there.
A good mattress does not need a topper as the best ones have pillow top built in.
A super quality Beautyrest mattress is an investment for life. Will set you back $5k+
We do not like foam mattress toppers. They retain heat and make it too hot for comfortable sleeping. Others seem to like them. Just personal differences. We use Sealy Posturepedic (firm) bought at Costco, home, cabin, and RV. Different sizes, same good sleep for us.
I’m curious.
What was the return policy for the mattress that you returned?
The reason I ask is because the memory foam mattress that I have is way too firm for me, but the return policy (on Amazon!) was so expensive for the buyer that I bought a couple of mattress toppers instead of returning the too-firm mattress. :money_mouth_face:
This is my old inner spring mattress:
https://www.walmart.com/ip/Signature-Sleep-Contour-8-Independently-Encased-Coil-Mattress-Multiple-Sizes/11600834
Looks like it’s been discontinued, but it was very comfy for eight or nine years, which is pretty normal for an inner spring mattress, and even more impressive considering how inexpensive the mattress was ($189 for an 8 inch queen mattress.)
That is a good deal
I really liked my inner spring mattress, but I like my current memory foam setup more, which is good because it was more expensive.
I just hope that my memory foam mattress and toppers last enough years before requiring replacement. :slightly_smiling_face:
It was definitely worth it for me due to chronic low-back pain, and that’s based on the cost of a 3" topper for a King-size bed.
Purchasing a certified natural latex topper was a good decision, just be sure to allow it to “off-gas” as soon as it arrives. The perforations help with that, as well as provide a bit of air flow.
Best setup I ever had was a Sleep Number bed that The Bionical Woman advertised. I got the cheapest setup imaginable, JUST the mattress and air-pump. No frame, no box-spring, no display on the controls just buttons to inflate/deflate, and that’s it.
Stick that in a… “mattress baggie”… not sure what they’re called. Plastic zipper-thingy that you use in case kids pee themselves and you don’t want it soaking into the mattress itself. Extra layer of thick plastic to help prevent anything from poking holes in it.
Yeah, it’d still be dead in like 24hrs with my cats, so I dare not get that again.
Thin “breathable” topper (fleecey/sheepskinny, no idea of the actual material) on top of that, then a fitted sheet.
Anyhoo, that was like sleeping on a cloud. I’d deflate it nice and soft to sleep on, then firm it up hard when sitting on it. Unfortunately the constant inflating/deflating caused a seam to flex and pull apart to the point of leaking. Another replacement, and another leak in the same exact spot. Lasted 1yr each before the leaks, and after that I just left it on “cloud” and sat my ass down almost on the old box-spring anyway. Lasted like 7yrs after that.
I’m downstairs now and not in that room anymore, 'though the mattress might still be in good condition and usable, but I never got a more comfortable sleep as I did on an air mattress.
Oh, prior to that, I used to buy Intex and/or Coleman air mattresses from Target for like 20bux a pop, including the inflator thingy. Each lasted between 1-2yrs before springing too many leaks. Rubber glue would patch small splits on the seams 'til they’d just give way catastrophically.
After going through a few of those is when I decided to go bionical.
I don’t like foam mattresses because I don’t like that sinking-in-quicksand feeling, nor the heat buildup underneath.
Don’t like spring mattresses either, especially when the springs poke up and stab me in random places.
If I had to go back to a regular bed, yeah, it’s an air mattress or nothing.
I talked to a guy who sold mattresses and he gave me this advice:
Buy a stiffer reversible spring mattress because they last longer, and then put a foam topper on it.
I got a gel-infused memory foam topper and it has been great. (cooler in the summer)
Yep, my memory foam mattress and both memory foam toppers are gel-infused.
I haven’t had any issues with my memory foam being hot, but I get cold pretty easily (and I like to keep my bedroom somewhat warm when I sleep), so that’s less of an issue with me. :zzz:
Personally I prefer a slightly cooler room all year round. I like being covered up and it is hard to do that if you’re roasting!
I bought it from walmart and returned it still vaccume sealed in store.
Yea. that was another concern of mine was heat and sinking . I am so used to spring matress and I’m hot sleeper. Latex foam doesn’t really have that problem.
