Lights with 3200 or so seem to have the most usable levels and a max output which seems to be ideal for our needs, thoughts/opinions?
500 lm is plenty for general purpose/hiking/camping.
An arbitrary max output number says very little, the beam profile is going to be a huge determining factor in how much output you want/need. 3200lm out of a mule will look completely different than from a light with a huge reflector.
I’d worry much more about efficiency, tint/CRI, flood vs throw, UI, etc. before even looking at max output. I rarely need or even want more than 300lm anyway, but 1000 or so easily does the job in most cases. The higher outputs are just a novelty most of the time for me unless I need something that can offer a ton of light from ceiling bounce (the Q8 has been very useful when I need indoor area lighting at my job).
3200 lumens doesn’t appear anywhere NEAR 3x as bright as 1000 to the human eye, and remember just how recently these super-high output flashlights have been available.
A Zebralight H series headlamp and some spare cells would be useful. Good for hiking, cooking, reading, etc. If you’re camping in a tent add a small lantern like the 3-AA Siege.
I did 3 weeks in the back country with a Thrunite Ti-3, 0.1, 12 or 120 lumens roughly. I never used 100, occasionally used 12, generally used 0.1. I mostly made dinner or slept at hight, but we did get into camp a time or two at dark. 1 aaa lithium battery was enough for me.
YMMV.
I’m thinking 5 or 6 hundred max. I use 1000 at work and the battery lasts about a week. I’d be comfy with 500 and a spare battery just in case.
BLF Lantern, when available. A headlamp is my favorite because hands free is critical when it comes to campside activities. Where you plan on camping is also part of the equation, sleeping neighbors don’t appreciate bright lights.
While I agree mostly with the comments (thank you) having a light ‘capable’ of about 3200 really is useful. Yes while on the trail or in the campground very low outputs; relatively speaking,are all one needs and all one really should use however there are those times when more is better: looking around the lake or in clearings or well off to the sides and in those instances the upper output cited is just about perfect, in a flood type beam thank you.
One brand offers the following in an easy to carry/pocket flashlight: 3200 lumens for about 1 hr and 30 minutes-1000 for 3/40-350 for 10/50-100 for 38/40 and 20 for 152hrs all plus or minus. Additionally there is a strobe at approx 3200 but no sos which in my opinion would have made a fantastic light nearly perfect.
Our absolutely perfect light would have the preceding with the addition of a secondary independent led/switch for the time when the primary circuit and led has failed however improbable that may be (of course carrying a second light provides for that prudent back up)…
It really is amazing to get a fairly good look at what is looking at you (trying to decide if we are worth the risk for a few good dinners-coys/the odd wolves/bear thankfully the strobe has been all required for us to return safely, so far. Here in very northern NH/ME USA- a shoulder fired cq rifle and two pistols are ALWAYS with us for our treasured walk in the woods; for those interested a Beretta CX4 in 9mm with one 17- fully hardened by SP wearing glass by Steiner and a 9mm LCR for me , the Mrs always with her LCR .357…………
Weight is a concern for me on a backpacking trip so I usually keep it to a single light. I’ve backpacked with my Zebralight H600FdIII for years and it’s been a treat to use. It gives off 870 lumens which isn’t necessary around camp or even seeing the immediate area ahead of me. I have taken a number of trips after work on Friday and hit the trail at dusk or in the dark and the flood pattern helps me see my feet and all the rocks and roots without having to tilt my head down. It’s got a nice moonlight level that allows me to read in the tent and it’s been very reliable.
A headlamp with flood, decent output and a nice low mode is so nice to have, Zebralight or any of the other recent releases could be the ticket for you.
Hiking out West with larger expanses might call for a light with more throw (not to mention more scary critters!), but in the East, there’s often dense forest and no need for big throw.
I’ve done a lot of backpacking and thought about my ideal flashlight a lot lately. I have used various flashlights and headlamps through the years and a 3200 lumen hot rod flooder that eats up half its battery capacity in 5 minutes of use isn’t even something I’d consider. My basic criteria are as follows:
Headlamp. Must be a hands-free flashlight so you can set up camp or do camp chores in the dark. You can theoretically get by with a handheld light, but why torture yourself like that, honestly?
Waterproof. Absolutely no rubber flaps or easily preventable points of failure.
Pre-set modes, no ramping.
Intuitive UI, ideally separate power and mode buttons, no blinky modes whatsoever.
Low mode of 10-40 floody lumens for inside a tent.
Medium mode of 80-150 floody lumens for around camp.
High mode of 300-500 lumens for sporadic use while night hiking or checking on noises at the edge of camp.
A nice 4000-4500K tint can be a nice touch to set the mood in camp if you don’t have a fire, but is definitely not a requirement. I’d much rather take a headlamp in cool white with good battery life and a floody beam over some handheld flashlight with a warm tint but terrible battery efficiency.
I wouldn’t rule out packing a mini thrower when camping out west, but even then, I wouldn’t consider it essential. It can be nice to spot moose on the other side of a lake at night or confirm if a bear is trying to get down your food bag or if it’s just a squirrel, though.
My latest headlamp I’ve been testing is the YLP Panda 2M CRI, which is the best so far, although I haven’t used it enough to say for absolute certainty how good it will perform.
One more thing to note: In camp with other people, you’re going to want to turn your headlamp down, like headlights on a car, so as not to blind other people, and you’ll expect the same of them. I’ve found that a lot of, if not all of, those 90 degree headlamps create glare in my glasses when angled down like this, which can be especially annoying when camping and your glasses have dirt on them. I need the reflector or lens to be a a little bit projected out from my head so as to avoid this.
Around the campsite or in the campground I would agree that a headlamp is a good choice however it is far more convenient/quicker to lower the output on any handheld flashlight that fiddling with a headlamp or at least it is for us. Where a headlamp is categorically the best choice is for trade use and we have several Petzl Duo S lights that we use for mechanical service, yes these are very high end and really any quality product would work very well we just always have purchased big dollar tools and instruments, usually one gets what one pays for.
As for hiking there is not enough spill and output for our needs with headlamps and this is where max lumens in the range I cited really shine so to speak-the Mrs and I have to be able to see out to a distance any creatures/quadrupeds which are watching US deciding whether or not to have a go plus having a strobe has in the past proved effective in dissuading aggressive animal behavior; shooting is always an option but only one of last resort.
Of course a strobe is very effective for use on two legged predators also.
Sounds like the ft03 in xhp50.2 would fit the bill. Great distance shooter, decent spill, high lumens and Narsil to boot.
Love my new little toy, so will plug the WK30. ![]()
Very lightweight for its size, yet packs a come-with 26650 (which clocked in at 5380mAH, over twice the runtime of a typical 2600mAH 18650). Great LH351D for white light, plus red and UV LEDs!
Reviewed one, immediately ordered myself a spare, it’s that nice.
Do you have a link for that light, please?
It’s very unusual for a pocket flashlight to sustain 3200lm for 1h 30m. The vast majority of lights like that step down after a few minutes.
As a guide, a 1×18650 light will normally be able to sustain 1000lm for a maximum of 1 hour, assuming it’s been built to get rid of the heat without stepping down or becoming too hot to hold. That’s a fundamental limitation of current technology, so there’s no way round it.
I'm sorry .....I just googled the Petzl Duo S.
I have no comment .
Friendly advice…NOT an attack/criticism…dont let your desire to be right, get in the way.
On a hike, you’re going to want to carry a backup light anyway. So, use an efficient headlamp with modest output as your main light. Something like a Zebralight H600 with a frosted lens, for a good floody beam. Run it at a couple of hundred lumens, and it will last all night. When you need more light, use a regular flashlight to blast some lumens in a particular direction. You can use that for 3000 lumens if you want, and don’t have to worry about wasting the battery or it overheating since it’s not used for long periods.
Yes, “high end” would be a good way to describe the Duo S. That looks super cool, although big enough of a head contraption that trade use is going to be the most practical for most people’s needs. I wish other headlamps had an auto-dim function for around camp when two beams cross.
Back in the incandescent era, I somehow was able to follow leaf-covered trails in autumn with a dim (probably 60 lumens on a full battery) Petzl incandescent headlamp. When I finally stepped up to a 360 lumen LED headlamp, which was a Fenix HP25, I felt like a whole new door had been opened up. Suddenly, I could see everything, certainly any faint trail at night for as far as I needed. I can totally understand wanting more light if you are bushwacking, although I don’t personally see the appeal of extended off-trail travel after dark, so I just do not do it.
Don’t get me wrong, I’m not trying to say nobody should have 3200 lumens, and if some flashlight company figures out how to make a light capable of sustaining that level for long enough to be practical on the trail rather than sucking down battery charge rapidly and burning my forehead, I’ll be the first to buy it. I’ve been able to get by with a lot less, though, and there are some good options that output a lot less — there are also some not-so-good options that output 2000+ lumens. My most recent test headlamp was the Thrunite TH30, which can output 3350 lumens on turbo, and I tried an Acebeam H30 before that, which is in the same range. Keep in mind that’s not sustained lumens, at all, and if you use it on turbo continuously, you’re not going to have a good time in the woods. Overheating, rapid battery drain, low battery warning flashes, thermal protection that dims the light and limits your ability to use it on high again…. I just don’t think we’re there yet.
As for using strobe on animals, that’s a new one to me. I never thought to try it.
Using strobe to scare animals does not work for me. A fox will not like it and trot away, but coyotes pretty much ignore it. Deer will slowly feed in the direction opposite from me. Rabbits will really take off with any strong light. Have not tried it on bear or mountain lions yet. Hope it will work, but I will not rely on it at this point. Others might have had better luck. For a human aggressor would it just be an irritant or would they be stopped? I like a headlight for camp chores and a thrower for animal identification. Self defense is in a different category, but whatever works for you.
The Fenix TK35 UE is one light that we have and find to be exceptionally useful while we haven’t decided for sure yet it just may be the perfect light for general use. As for how long the max output is available-I don’t know as we only use the highest setting for a few seconds to a few minutes at most as I think would be the case with nearly all other non professionals (not search and rescue or police/fire/military) though I will post that under most all circumstances high power can be a high liability, all those lumens bouncing back at you from windows/mirrors/bright metals and brighter painted-bare concrete walls and flooring/sand takes its toll quickly, I post-regrettably- from experience. And all these ‘hazards’ are generally present while hiking and camping. So while high output has a use it must be used with discretion.
Generally for us there is not a whole lot of difference between output levels over 2k lumens, certainly some but not a breathtaking amount BUT in some situations a little really can be a great deal.
As for a strobe being effective in keeping predators at bay-our experience is that it works and works well, perhaps what is key is the rate? I cannot imagine any animal, two or four legged, attacking what it cannot clearly see; if anyone takes exception I would be very interested in comments.
Should you have an issue with pests in a building or attic-consider grabbing a few inexpensive DJ type strobes, set them up and turn on for a few days or so and see what happens. For us the problem goes away-always, it has never failed BUT remember to turn on the lights after you have exited, I had to rescue the Mrs. on one occasion but only once.
Disclaimer- our results with the lights we used in the application we used them in for control of the pests we had-racoons, mice, squirrels, birds and chipmunks……………… As they say, your results may vary-we are not experts and caution against using only our experiences as the basis for a purchase.
