I was about to try another white wall shot, and checked that the light was on high mode, and, just looking at the screen (I was using the camera from my tablet), I could see the lines… kind of like when you look at a TV through a camera.
I think that what you said earlier may be correct, that there’s PWM when in high mode with that original driver. When I was measuring the current, I could see the meter reading fluctuating all over the place.
Hey Jim sorry for the late response. Yes it sounds like your seeing a driver with PWM in high mode (I don't think that's common, but as you found they are out there). Yes, measuring tailcap current is generally without a switch in the circuit - one meter probe in the (-) end of battery and the other probe on the threads or flashlight body to complete the circuit. The drop you measured across your switch sounds awfully high, but others would have to chime in on that. The 1.57A sounds like it should be okay for the XP-E (your not overdriving it that much, although I'm not real sure of an XP-E's "true" limit).
I was “on a roll”, so I did tailcap current measurements on a number of the lights that I have. Recall that all of my lights are “out-of-box” from commercial vendors, i.e., no mods yet. Anyway, when I did all of those tests, all of them measured ~1.0V - ~1.5V. I guess that I wasn’t so much surprised, but a little disappointed, at those results.
Thinking about it though, I was wondering if, maybe, manufacturers are more conservative with their designs, and because of that, when they design/build lights, they purposely don’t drive their lights very hard?
Sorry about that. Yes, I meant “amps” not “volts” :(…
And thanks for confirming that this is typical.
But, I wonder is that even the case like with the “stock” Kaidomain C8s? I’m assuming that vendors like Kaidomain mod some OEM C8 (or whatever host) with new drivers, in order to be able to claim 2.8 amps, and lights like that would actually show current that’s higher than the 1 - 1.5 amp range?
I should add more. Many stock lights out there go higher. Sometimes, you don’t get the same current due to batteries with high resistance or resistance within the flashlight. Also, your DMM’s leads may have a lot of resistance.
Hopefully, someone with more experience in this area can give you some input.
before you get all het up, I assume you have a 2.8 or 3 amp nanjg on the way.
If not, get one on the way asap, with this, build a drop in or c8 pill then use this to confirm your meter will read 2.8/3.0 amp reliably. If your using a cheap meter you may have to make up some low resistance/high current test leads.
I would generally hope to be getting 2a or so to an xm-l, although I’m regularly disappointed in this respect and now count on most lights being “hosts” as the emitter tint,modes and drive current will not be what I want. This is the beauty of modding, getting what you find most usefull in a light.
I wanted to let you all know, esp. for those of you who were encouraging, that I happened to also have an “Cree XP-E, 16mm Star MCPCB, R2, WG tint”, and I ended up putting that on the drop-in, instead of the 10mm Nichia PCB, and it was EASY (like some of you already said… ok, ok).
I was just outside with an L2P with the “new” pill, and while it’s not as bright as the original XM-L emitter, it was really able to throw… a very narrow, bright beam that was able to reach across to a stand of trees, about 150 yards. Hardly any spill though :(…
Thanks for the update. It always to good to recover a light up to at least some level of functionality. Thanks for the beam info. I haven’t owned or used an xpe yet.
