basically? i have wanted to direct drive an xml or xml2 light…
i have arrived at 3 “ideas” for what direct drive means… and really? the big modders here have a tendency to say things like…
“yeah, i took one of these, and direct drived a xml off it? it had a big wow factor when the guards saw how bright this little cheapie was…”
idea 1 = battery, connection to emitter, nothing else. rather like the LED equivalent of a regular old fashioned incan light was constructed… battery connected to switch and bulb (led). i was thinking single 18650, xml/xml2.
idea 2 = same as idea #1, but, its “understood” i am inserting a small value resistor inbetween battery and LED (current limiting resistor) calculated for nominal amperage.
idea 3 = NOW i am seeing on mtnelectronics site?? FET drivers, being called “direct drivers”…
my THOUGHTS were that if it were “idea 1”? the LED (xml.) would simply “draw” what it wanted/needed from the 18650 and would heat up and “settle into” a current pattern… or is it “understood” i am to be using a current limiting resistor? or… does direct drive “understood” to be a FET driver like the ones mtnelectronics sells?
inquiring minds wanna know… i just wanna make a super simple “wow light”.
