This would be my advice: either have a calibrated light source with known intensity, or have your luxmeter calibrated.
I have had my pro luxmeter (Hagner E4X) calibrated at the beginning of this year. It read 5% off from a few years ago.. so they do slightly change over the years, but I’m not sure how much other luxmeters can change over the year(s). I’ve dropped or bumped it a few times, so that might be the reason???
I’ve bought a Testo 545 Luxmeter last year and shipped it to 1 of our 1Lumen reviewers, and its readings were 20% off. But I didn’t want to open it up to see if I can manually tune it.
But as long as you have a calibrated reference, you only need to do a quick calculation at the end.
Basically, you can’t rely on anything unless it’s calibrated, or you have a light source with a known beam intensity, where you will get your correction factor from.
I have had quite a few luxmeters, and some of them can be opened, and manually adjusted. (that’s probably what calibration looks like anyway). And you have some small dials that you can use to get the measurement finetuned.
I finetuned/calibrated a "LX101 Light Meter"and a Extech HD450 based on my pro meter, and its readings were very close to my professional meter. I havent tested it recently, so it might have gone off a bit again.
You could open up the LX1330B, and see if you can see some small screws that you can adjust the readings. Having a light source with known beam intensity is actually the best, either way if you want to finetune it yourself, or just use a calibration factor… that’s the way to go.
I send a flashlight with known lumen output to each new 1Lumen reviewer.
I measure it in my integrating sphere, and include the candelas measured with my pro meter at 5 meters distance at X seconds.
The reviewer can base their integrating sphere measurements and intensity measurements on this calibration light.
Regarding your ways of measuring. Doing an average is fine.
I do them manually, where I put my flashlight down, and manually move the sensor around to get the highest readings when I do 10 or 20+ meters measurements. My luxmeter doesnt have a Max reading setting.
My eyes are still doing okay to see the screen of the luxmeter at 5 meters disance, so that’s where I do it the other way around, and move my flashlight instead of the sensor.
Also, ideally a measurement should be done indoors at X degrees ambient temperatre.
I can’t do any 10 meters measurements indoors, so I have to do it outdoors.. with temperatures always changing.
Besides that, I would advise measuring a certain type of flashlight always at the same distance. Small EDC at 5 meters, long range at 10 meters or 20 meters..
But be consistent with the distance. That way, even if you’re readings are a bit off, people can still compare the measurements with its competitors you also tested. I wouldnt worry about 5% difference or even just a bit higher.. If it’s consistently higher than 10 or more, I would.
