Tom, great response. It seems there are some who believe that since CREE has tight tolerances with their emitter mfg process, that the differences from light to light would be in .0001% range but I've had samples of two lights where the differences in output were closer to the 10+% range (with max output @ ~3500lms). Of course this needs to take into consideration the potential differences beyond the emitter itself, however, suffice to say that I've been very happy with my PVC LMD set up.
The only thing I've altered since I first posted this is I now cut out paper templates to block out the gap between the light and edge of PVC. This minimizes any advantage for lights with large bezels since there is less light lost. Of course, the foam method that others use achieve the same purpose. I also didn't use the step down tubes but instead have the light meter clamped to the end with a black cloth surrounding it (to prevent from measuring ambient light). With this set up, I can measure from .1 lms to 10K+ with the main caveat being that I only have one reference light, a Xeno G10v2.
As for the temperature swing, it can actually be in neighborhood of +/- 5% but again, for our intents and purposes, that should be more than sufficient. Having a solid reference light and calibrating with it before each measurement will greatly minimize any differences from temp swings.
In the end, if you end up with a setup that produces consistent results between various lights, that's what matters more than being .0001% off vs. claimed ANSI lumens ratings.
mhanlen - The light meter can be any reputable one and the one Tom linked above should would perfectly fine. Again, it's the consistency that matters above all else.
I'm about to try figuring this out tomorrow. I tried to find the 4 inch p-pipe that turbobb used in his pvc integrating pipe, but my hardware store didn't have it. I'm just going to use a white bucket I already have, plus some white corrugated polypropylene and a small sheet of glass. The corrugated sheet will serve as baffles. My lux meter doesn't have a remote sensor, so I'm thinking I'll attach the lux meter to the bucket with magnets to make checking and reattaching it easier and more consistent. Later on I'll get another lux meter with a remote sensor.
