Hello, guys! We are ready to present you our NEW addition to the tactical lineup!
Meet Viking Pro Magnet USB!
Impressive features of Viking Pro Magnet USB flashlight
Viking Pro is a new generation tactical flashlight with soft wide light for hunting in open areas and for specialized tasks. The flashlight can be used right out of the box: the set now includes a high-capacity battery and a fast magnetic charger.
Large central spot and wide side spill make Viking Pro *perfect for short- and medium-range *use with maximum distance of 284 meters.
Wide beam of light allows to comfortably highlight the objects at close distances of 50-70 meters with the brightness reaching impressive 2050 lumens.
Powerful electronics provides constant brightness even at a temperature of –40 °C and not fully charged battery.
Total protection from water, dirt and dust in accordance with IP68 standard — flashlight continues to work even at 25 meters depth up to 5 hours. Withstands fallings from the 10th floor.
Advantages of tactical flashlights with magnetic charger:
- Non-flat button allows to easily switch the flashlight with a palm.
- Active real-time temperature control to prevent overheating above +58 °C and warning indication of low battery level.
- Magnetic charger in the set
Order Viking Pro Magnet USB today at armytek.com!
Thank you for choosing Armytek!
