Heyo. I recently lucked into possession of a vintage Olympus BHS microscope. These things are cool, except for the 100W halogen goiter hanging off their backside. That thing... definitely is not cool when it's turned on. Plus the bulbs are mad expensive these days.
So, having no experience with making lights before, I've sought to replace the halogen lamphouse with a dimmable high-CRI LED (or set of LEDs.) I currently am thinking of the SunLike SAWS1566A COB (25W), which has excellent CRI & R9, and more output than the original halogen bulb. I'm aware it will need a decently sized heatsink that won't fit in the original lamphouse, so I will probably cannibalize the lamphouse for the front lens housing that connects into the microscope and attach it to a big Cooliance heatsink.
I've been doing a LOT of reading in the past couple of days. Where I am out of my depth here is... okay, everywhere... but especially the electrical stuff. I understand that I need a constant-current driver that outputs 720mA current (700mA would also be fine, I suspect? just slightly lower output,) @ at least 35.2 volts, and I need a power supply that takes 120v AC power & outputs DC power within the accepted voltage range of the driver. That sounds straightforward. However, I've never built a light before and the sheer amount of options here is overwhelming. It seems there are about a billion brands of drivers and power supplies. I would appreciate any advice on what I oughtta buy.
Lastly comes the thing I understand the least: PWM dimming. How do I do this? I would like to have a dial dimmer, but my caveman brain knows very little about PWM except that higher HZ = better (less visible to the eye & to cameras.) Any literature on this subject, or else a dumbie-proof suggestion on what to buy, would be appreciated.
No idea what fits with what, but a CPU cooler with fan can be attached to the COB, and it’d allow more cooling than just passive cooling like most lights. Then you can bolt on the lens and worry about the electronix later.
I did think about using an active CPU heatsink initially, but it turns out vibrations in microscopy (such as may be introduced by a moving part like a fan) are a very bad thing! Any minor movement becomes amplified by, well, about a thousand times.
The best heatsink option I’ve found so far is Cooliance’s stuff, which is specifically designed to passively cool COBs.
I would look at Meanwell LED power supplies. The dimmable ones. LPF-40D-42 might be ideal. 3-in-1 dimming function, so it can be dimmed by several methods as described in the data sheet.
The dimmable one looks like a 100k pot can be used to control dimming. That make it turn a knob for brightness.
The original bulb should have made around 1400 lumens and the COB the OP linked makes 2655 lumens at 720 ma.
Reducing the current to a little more than half (say around 450 to 500 ma) will make the led run more efficient with less heat and would be easier to cool with more light than the original. I’m no expert with microscopes, but if you get to much light shinny on something your trying to see you cant hardly see anything, it just looks white. It over saturates your eyes. Maybe that’s not the case here, but just seems like a lot of light to me.
That’s the idea - you have a lot of light on tap for things like micro-photography (cameras have a hard time with low light, like microscope images) or microscopy techniques that consume a lot of light (like polarized microscopy - which uses a filter to polarize the light, and that filter eats a good % of the light.) Then for regular brightfield you have a dimmer to turn the emitter down to normal levels. As I understand it, dimming with PWM is very efficient.
From the linked page it shows a 50k pot being used to get about 50% of the rated current. It looks to me as though the pot rating determines the output current.
Its in a graph about half way down that page.
is the halogen light source focused in anyway? cuz if it is, most likely focusing system will not work with led, i tried converting lcd projector to led, did not really work out.
this is high precision optical instrument, i bet it is really expensive, i would not mess with it
Understandable then. If you look right below the pot to current graph they also have a nice wiring diagram to show how it would be wired up. You might give them a call and ask a few questions before you decide.
I think I understand how potentiometer ("pot") dimming is accomplished now, thanks for the advice all. Am I wrong in thinking that PWM dimming is ideal compared to potentiometer dimming?
Yeah, “point source” from the bulb, big surface area from the COB. Light’ll go in allllllllll sorts of directions, and most of it not in the direction you want it to.
yea, definitely focused, no, i would not mess with it, unless you want to ruin it. to do it properly is a lot harder than it looks. entire optical system will have to be redone.
what bulbs does it use? those are bipin bulbs, maybe you can use a different bulbs, if you can’t find oem, what is the voltage and wattage? i have few bulbs that look just like that
s. i googled it, that is $3000+ instrument, are you gonna use it for intended purpose? if not sell it. it worth good money.,
that bulb looks like 15v150w, or 24w 250w, but gold color pins tells me it maybe something more, a special purpose bulb, unless they just look like that on the pic.
The BHS bulbs can be had online (for not-very-good price) but they last a median of 200hrs and the tint & CRI characteristics are, well, not good. The power supply is also 70s-era stuff and breaks down with some regularity. I know it's possible to use some combination of lenses to use a COB for this microscope - there are existing LED lamphouse replacements that use 10w Epistar COBs (super-vomitous tint, CRI and output.)
The optical requirements here are not as nuanced and intricate as you would be led to believe from the picture of the lamphouse interior above. The light doesn't have to be perfectly collimated into a shaft when it leaves the lamphouse. It just has to get out of the lamphouse and into the collection tube. It goes down the tube, hits a prism that tosses it upwards, where it hits the condenser. The condenser is what collimates the light for focusing on the specimen.
pdf says the bulb is 12v 100w, but the flat winding of filament is like no other 12v100w i’ve seen before, has to be special bulb, unless the bulb on your pic is not original.
If you are willing to try to retrofit to a COB led, then have at it. That’s how alot of us here got into this hobby. Anywhere there’s a incandescent bulb we try to figure out a way to change it to a more efficient led bulb. I just finished modding my headlights to led a few days ago. I purchased led headlight bulbs that used xhp50 leds, I ordered 8 xhp50.2 5000k 80 cri leds and set in changing them out for the better cri and higher output. Worked like a charm. More light and better color retention than the yellow incandescent it came with.
I say go for it, you may learn a lot and teach us something along the way. It will require some trial and error and lots of reading.
