This is basically just my simple impression of this driver along with some measurements and resistor fiddling. I paid 5$ for it. Link to driver.
Thanks for the very informative testing, a pity that it is not a very good driver.
I started reading with the hope it would be the driver for a 1x26650 mod I am working on (should also be 22mm) , but this is totally not it. (so I will use the cheapo direct drive stock driver with the resistors shunted)
Thanks for the review. I could see using this in my Lawnmower headlight mod (with next mode memory removed), but then again the Fast Strobe on a lawnmower might appear out of place :) . Watching for the "mods". Would like to see a little more output.
-Garry
Thanks for the feedback..
Djozz. Sorry to disappoint you. I had hoped this was driver was a hidden treasure.
When that is said, its a buck driver. It will not light up an emitter with a single battery. That I expected.
It will stay regulated down to about 5,25v input. It will light up an emitter with 5V input, but not with proper output.
Garry, for all I know, it might be fine at 3A or more, but for now, Ill wait and see if anyone have tips for improving the memory.
Thanks RaceR86. Nice try.
No input on removing the next-mode memory?
-Garry
Oh, I had already forgotten about the annoying next mode memory when I posted about this driver in the other thread.
Hoping someone will offer a possible fix for the next mode memory.
Hmm - found a very similar driver over at DX. Then found this customer image showing a resistor added. Not sure if that helps any.
Oh, and one of the reviews says "doesn't remember last mode". Hmm. . .
EDIT - OOOHHH! Found this! And this thread discusses.
EDIT #2 - Another DX thread showing updated board like LightsCastle's with single mode mod.
-Garry
