As you’ve probably already read, ThorFire’s upgraded C8s was recently released. Several BLF members have already done a great job detailing the upgrades and overall flashlight. So I will just add a bit and reinforce some of what has already been said.
Freefly’s Addendum: Review: Thorfire "Upgraded" C8s #2 (addendum to ReManG's review)
ReManG’s Review: Review: New Thorfire C8s from Amazon, Updated with 3+ Amps on new driver.
Tailcap upgrades:
A while back I bypassed the driver and tailcap spring on almost every single flashlight in my possession. That included the older Thorfire C8s threaded pill version.
Tailcap current (Amps):
| Mode | ThorFire C8s Bypass V2 | ThorFire C8s Stock V3 |
| Moon | 02 | 02 |
| Low | 09 | 09 |
| Medium | 80 | 792 |
| High | 3.20 | 3.18 |
Measured with a 30Q at 4.17v there is very little difference between the two. It appears to be the same driver in both versions. Spring bypass seems to do very little here.
All throw measurements are lux values taken at 7ft and calculated back to 1 meter (Rounded to the nearest hundred). Ceiling bounce numbers are just simple lux measurements of various lights to compare relative output.
The C8s stands up very well in the variety of lights. The output and throw of the new C8s is comparable to the notably larger X3. The new C8s also destroys the rather outdated XML Convoy C8, doubling the throw with a significant increase in output.
This is the older threaded pill ThorFire C8s version:
The upgraded ThorFire C8s:
The copper mcpcb thermal pasted onto the shelf. There is a small divot in the integrated shelf (little anodized spot in the center).
The underside of the integrated shelf.
Simply put, the upgraded ThorFire C8s is a very nice flashlight. It is the best C8 I own, with the older threaded pill C8s coming in second. I like the upgrades to the tailcap very much. I never really noticed how recessed the old tailcap clicky was until I got the upgraded version in my hands. The switch is quite substantially easier to access now. Great job ThorFire. ![]()
I’d like to see perhaps an XPL-Hi version, and/or tint options as possible future upgrades/enhancements.
