Awhile ago, I found that ledsupply.com was clearing out their Luxeon triples (http://www.ledsupply.com/07007-pw740-l.php), for some reason, I got kind of obsessed with building something with them, so I’ve been wanting to build a small light that uses it and a Carclo 10507 (narrow) optic. In my mind, it felt like a tube-style host would work best, because a host with a head that was wider than the body wouldn’t fit the 20mm optic and triple very well.
A couple of things came together:
- relic found a really cheap tube-style light on ebay, a UF S5 (1x18650 XP-E Flashlight for $2.99; Deal?), and I bought a couple of them to experiment with. The nice thing about this S5 is the way the head assembly is designed. A retaining ring holds the pill against the reflector which pushes against the lens, so it easily accommodates the shorter Carclo lens.
- I also didn’t want to drive the triple in parallel but, rather, in series (less wiring), so I looked for a driver for a long time, and almost decided that I’d have to use direct drive with just 2x16340 or 2x18650. The problem with direct drive is that the triple in series needs about 1 amp at 9V, so with just 2 Li-Ion, the emitters were seriously under-driven. Then, I found this boost driver from CNQ:
The CNQ driver is perfect, because it is a true boost (outputs whatever voltage is needed, in this case, 9V) with 1 amp, which is what Luxeon specs as the max current for the emitters . It’s a double board driver, which is a pain, but it turned out that the smaller board fits the S5 pill/ridge.
So, at that point, I had all of the pieces to mod the S5 to use the triple, and it was just a matter of squeezing it all into the host.
Parts:
- Ultrafire S5 (Ebay)
- Luxeon triple emitter (ledsupply.com)
- Carclo 10507 optic (ledsupply.com or illuminationsupply.com)
- CNQ Boost driver (http://www.cnqualitygoods.com/goods.php?id=1391)
- Small disk to fill in emitter side of pill (made from penny)
- Arctic Alumina (to secure the driver in the S5 pill and the disk to emitter side of pill)
- Fujik glue (to secure the driver in the S5 pill)
- Driver spring (reuse the one from the original S5 driver)
Here’re some pics of the pill mods:
This is what things look like when they’re all stacked. This whole stack just slides into the S5 head, and then the retaining ring screws in and secures it. In this pic, you can also kind of see how I “extended” the two holes in the pill down the side of the pill so that the emitter wires would not push the emitter PCB up:
The smaller board of the CNQ driver fits into the original pill, but the +/- contacts on the triple are both on the same side, so I drilled a 2nd hole in the top of the pill. I also used a small round diamond file to both open up the drilled hole and extend the hole down the side of the pill as can be seen in the pics above. The reason for that is so that the emitter wires would not be under the emitter PCB and cause the emitter PCB to be raised up.
I shortened the driver-to-emitter leads, then soldered the leads onto the triple.
I then used some AA around the driver side of the pill and then glued the small board onto the driver “ledge”. I let that set, and then used Fujik to fill up the empty space between the two driver boards.
[Note: I think that I should’ve filled the pill with Fujik before AA’ing the smaller driver board, but I realized that too late. This is because now, the only thing holding the driver in place is that ridge and the AA.]
I used the spring from the original S5 driver and soldered that to the CNQ driver, and then shoved the stack into the S5 head, screwed the retaining ring on, and VOILA, we have triple (de)light :)!!
