Modable HL
Looking for a 18650 lamp thats able to be modded like that of the Convoy lights.. able to change out the driver, led, lenses and so on..
Thought about getting one of the cheap ones off of Amazon or Aliexpress and hope i could make it better.
But rather just get a good one frome the start.
Live my Streamlight 1000lm but it still has the micro usb, funky battery and no way to swap out the driver, but i could swap out the funky shaped led with a 16mm..
What says the zombie horde ?
Why not a Convoy Headlamp then?
Im definitely looking at those, for what ever reason ive looked past those types and looked at the ones that have the light centered.. has a bigger reflector..
But im weird and hard headed..
Let me go read up on those again.
These are fairly moddable too:
https://www.sofirnlight.com/products/h25l-rechargeable-headlamp
Not that particular name brand but the exact type id been eye’n… even think it said it had SST-40 led’s in it.. put a 60° Beaded TIR lens on one side and a 5° smooth on the other ?
I dont know, just ideas.
There are many different variations of this style and i have seen some people add tir lenses.
I modded a Wurkkos H25S with new emitters. I reflowed 1 LHP531 5000k and 1 4000k to the fiberglass mcpcb.
I like it a lot.
I don’t think the driver is easy to mod though.
It was a little finicky to mod.
If I recall correctly, the ground plane relies the the mcpcb being properly secured to a bare section of the head. It wouldn’t turn on with the mcpcb outside of the head.
I thought I had screwed up the mod.
Turns out I just had to establish the ground.
I figured that out when I bridged a contact on accident. Hehe.
Reassembled and it worked good.
Not a high recommend for a new modder though.
It uses a weird ribbon cable that is a bit of a pain to work with too.
The mcpcb is fragile and seems like it could be easy to destroy.
Other than that, it is easy to take apart since the front is held on with 4 screws.
I think I’m gonna have to mess around with a Convoy H1 now. 21mm driver is kinda weird, but I could probably sand down a 22mm driver.
The DDH clicky hosts from Kai Domain are awesome.
Have you a link? I trawled their site for a headlamp not that long ago and didn’t see anything by DDH?
Went with a KDLITKER HL10 5050-L2 500 Lumens 3-Mode 18650 Headlamp which is.. okayish? It’s got slightly disappointing build quality (floating LED assembly) and as a result not very bright in stock or modding potential.
I replaced the LED and documented it in this post
This is one of my favorites. They aren’t labeled as DDH. They are manufactured by DongDongHai or DDH. Great hosts and easy to mod. Kai domain offers a few models. They all look similar having a unique style to them.
The K29C is a DDH-G1C:
Pictures
Dang… thats got the biggest head ive seen in one of thos styles, should help keep cool..
Just to mention it - what about the Sofirn HS20?
It’s moddable if you can reflow solder, it uses a simple 5050 and 3535 emitter.
Probably the last Sofirn headlamp you can open without destroying it…
https://www.sofirnlight.com/products/sofirn-hs20-rechargeable-headlamp-spotlight-floodlight?cfb=d894422d-22d8-45f2-9db4-f6ec04f23ecf&scm=collection.v38.11095.202.203.204&score=2.311202463389747&ssp=-
That’s my headlight of choice, but for different reasons.
I don’t think it’s gone on sale for a very long time. :upside_down_face:
It was on sale in May for $25 - which is why I have two of them :sweat_smile:
One has a LHP531 6500K and a 519A 5700K - good combination.
The other has some round die emitters, but those don’t work too well in that light, I will wait for the High CRI LHP531 and hopefully LMP 3535 Emitters
I have one with an SFT40 emitter.
If that one goes on sale for $25 (and I hear about the sale), I’ll buy a second one. :+1:
I have not done well with reflow soldering.
I can get the led off easy enough, but out of 3 tries ive just destroyed the led.. need to find more sacrifices to play with..
A small hot plate will run you $15-$20 and it’s of great help.
I used one of these for about 2 years before it broke and I upgraded to an adjustable temp one.
https://a.aliexpress.com/_mOb8OWf
In my opinion, 220C is perfect for MCPCBs.
I ordered 2 more of these cheap ones as backups.
Funny, my handle on YouTube is Trashpanda..
