Well, maybe a 12 volt would be good. I have always found that DC fans like that will operate in a range of voltage. Higher voltage may shorten their life span, no doubt. I will run it till it dies and then worry about it, but when I do replace it, I will use a 12 volt. I probably have one lying around, except it’s probably much bigger.
I like the idea, I might try to mod mine too. Can I install a potentiometer in series with the fan to be able to adjust the speed manually, depending on the number of cells I want to charge and so?
You could use a pot depending on wattage of fan (too high and it will burn the resistive tracks), but better to use PWM to control the speed, you will get more adjustability from a pot.
I found this which is only adding a 74AC14 IC, two caps and two diodes:
if I read the text correctly. O-L’s fan is 350ma so may fry the chip used in the link? That’s a neat circuit to build from so maybe add additional driver.
Just wrapping the capacitor leads around the two leads on the right then kapton taping it to the chip would make it much smaller, then just a blob of hot glue to the lip under the top and bottom of the fan and viola…tiny voltage regulator to run the fan at a “alot quieter” speed, still getting enough airflow to keep the internals cooler but not loud enough to be a dental drill
Ick. IMO fans are something not to skimp on, similar to batteries. If I use a fan to cool something I want it to be fairly dependable. (If noise level/signature bothers you then not skimping becomes even more important)
My personal preference is for [my own] things to be fanless up until the point where a fan is necessary. If a fan is ‘necessary’ I sure don’t want it to stop spinning.
