Modding a vintage 2d light. I have no idea what I'm doing!
Ok, well, I have a LITTLE idea what I’m doing….
This link popped up in an older thread about modding maglites, so I’m thinking it might be just what I need.
https://www.fasttech.com/products/2201/10000795/1263204-mr16-3w-3-led-3200k-250lm-warm-white-led-light-bul
My question is… With the stock 12v driver discarded, would it run directly off 2 alkaline D cells, or do I need a different driver of some sort? I’d prefer only one mode…
I suppose you could pick up a 3V boost driver from illumination supply or one of the Chinese vendors but at only .5A it will be pretty anemic compared to what you could do with a couple 3 x AA holders or some lithium cells. The LEDs are probably wired in series so you’re looking at needing 9-10V to get it working unless you rewire for parallel to get down to ~ 3.3V.
I’m figuring on running them parallel, like in this thread. https://budgetlightforum.com/t/-/13696
It’s the drivers I’m really confused about. How do you tell how many volts those bulbs should be getting?
They should get ~2.8-4.2v, that’s what the vast majority of emitters used in flashlights run at (the exception being the 6V MT-G2). Brightness is controlled by current, not by voltage. I have no idea what emitters that uses, didn’t look but I know for a fact they run at ~3v.
