The reason the MT07S has a 4S battery configuration for a 6V emitter is to provide stable output as the batteries drain. I’ve found it complaint-worthy that other lights that could easily be configured this way often aren’t, such as the Nitecore TM16 (4S batteries, 4S emitters that could have been 2S2P instead).
I get it for FET hot-rods of course, but I’d much rather my general-use lights have stable output.
Nice comparison. I just received the Q8 and the MT07S and I agree. I like the build of the MT07S more. I’m just getting into this and I’m wondering how I would go get a NArsilM driver so I can get the ramping function as well.
how did you get the reflector retaining ring off? i just got mine in the mail and it has a bad rattle like the reflector or something is loose, i also have a blemish on my reflector. wanted to open it up and see if i can tighten up whatever is rattling .
Hey how are you doing man? Welcome to BLF! I assume you mean the stainless steel bezel? Just place the light on the palm of your hand, exert a pressure, and twist the body counter clock wise (like normal thread).
There is no glue or loctite, at least not on my lights.
If you mean the retaining ring at the board I finally had to grind down a pair of needle nose pliars to a point that would fit onto the little notches.
I didn't see any traces of thread lock but that ring was very hard to get off.
Side note... Once I did get that off the bezel was much easier to get off..
i got it, thanks for the help, mine was very tight so i used a leather glove and it came loose, just reseated everything and it stopped the rattle. what is the best thing to clean the reflector with after a fingerprint or smudge etc. Im a long time lurker here and finally registered. ive always looked and CPF but have wanted to get into modding lately and have discovered this site has a lot more info. i currently have a big pile of supplies from mtn electronics waiting to build my new c8 hosts, just waiting on the artic silver !!!
