Hi every one
I had an old plastic Coleman flashlight that had a very nice SMO reflector 71mm(D) x 55.5mm ( H ) well i wanted to use this reflector to build a thrower but didnt find any of my flash lights would fit with it so i had this crazy thought to mod this plastic host, well i had the challenge for a long time, but really how would i do it ? at 1st i thought to take the head and fit it with 2D mag body i tried to fit them and they would fit together but where is the fun and i may face heat problems and someday i got this Idea Lets see pics will tell
The Host
When opened to work as lantern
Dirty lens will be polished later
Head disassembled
Reflector
Reflector filed to fit the focus of the led that took so much time try and error.
And now the heatsink and the modding parts.
CPU Heatsink with a big chunk of copper, i think Intel uses a good copper.
The copper heart were taken out by a hydraulic presses.
Now modding the heatsink relax everything is coming.
The copper pill were machined to make a place for the led and made two holes for the wires.
Now modding the plastic host i made a place for the heatsink.
heatsink were assembled in the body .
Now getting everything together.
Finally the challenge were Done .
I am lucky the reflector fits GREAT with the Pill .
I have a big room i can put 4 18650 cells and a big Driver.
Rest is easy led , driver , switch now i am thinking how i will put the cells i may think to use a cells pack .
Sorry for the bad phone pics
To Be continued …
this host beside small sun ZYT-08
I decided to use a dedomed XM-L2 1A running at 6A, now the led dedomed and mounted
I used the driver TR-0124B from FT modded with the Trimpot
thanks for ImA4Wheelr and RaceR86
Head mounted
I made a side switch
Reflector and lens cleaned
It is hard to make a place for the cells for easy changing so i had to make a battery pack it is 2b2s and as temporary i will solder them directly to the switch and the driver tell i figure something else
Now it’s ready
i will try to post some beam shots as long as i have them
thanks for watching
