Ive got some lights that I need to get serious about selling finally. Prices are shipped in the continental US. If you are an international member you’ll have to pay actual shipping costs. I ship USPS priority mail and will strive to ship within 24 hours after I receive payment. Tracking numbers will be PM’d to the buyer once I have the package in the mail.
If anyone is interested in a light and wants more pictures please ask and I will try to post them as quickly as I can. It’s an aweful lot of time to just snap a huge amount of pictures unless they’re needed.
Edited to add: I’m open to offers if after a few days there hasn’t been interest on a light, but please be conscious of the fact that I don’t give my time away for free. If I can’t make something building these then I have to stop building them or be prepared to start sleeping in the garage all the time, not just when I fall asleep soldering. With that in mind don’t expect me to knock 25% off of these lights, if I did that I’d be down to the cost of just the materials to make a most of these, and it means I’d lose money on some.
Note lighted tailcaps cause the drivers to become next mode memory, I’ll be investigating to see if I can find a way to prevent this, but I’m not expecting a solution is to be found
Update, it looks like there may be a solution
Update 2: Mode memory working, shouldn’t be a problem moving forward
Update 3: Red and orange/amber LED’s for the tailcap will draw 3-4x the current as green, blue, pink, warm white, and cool white for equivalent brightness. Easily visible in a well lit room brightness is approximately 1-2mA in the more efficient colors.
- - Uniquefire 1504
Nubs have been machined, they are about 50-75% removed.
Brass pill, XP-G2 S3 3C on 16mm Noctigon, dedomed, MCPCB soldered directly to the pill.
Q.lite Rev A driver with 5 extra 7135 chips (more than is necessary with a 4.2v battery, on Efest purple tail measurement is 3.4 amps), soldered to pill, wire jumper on spring
Stock tailswitch
To my knowledge this is the highest output (throw) 1504 in existence for now.
Measured Candelas: 432kcd
Asking $105 OBO, I’ll replace the stock tailswitch with an Omten for $3, or lighted with your choice of color LED’s with an Omten for $8 Sold
- - Uniquefire 1504
Nubs have been machined, they are about 95% removed.
Aluminum pill, XP-G2 S3 3C on 16mm Noctigon, dedomed, Arctic Silver thermal adhesive used to mount MCPCB to the pill, painted black to reduce reflections
Q.lite Rev A driver with 2 extra 7135 chips (more than is necessary with a 4.2v battery, on Efest purple tail measurement is 3.4 amps), soldered to pill, wire jumper on spring
Stock tailswitch
To my knowledge this is the second highest output (throw) 1504 in existence for now.
Measured Candelas: 429kcd
SOLD
- - Uniquefire 1504
Nubs have not been machined, I will remove as much as you want for an additional $15 if the buyer wants
Brass pill, XP-G2 S3 3C on 16mm Noctigon, dedomed, MCPCB soldered directly to the pill, painted black to reduce reflections
Stock tailswitch
To my knowledge this is the third highest output (throw) 1504 in existence for now.
Measured Candelas: 425kcd
I dropped the price extra far on this light as I’m not happy about it having a small spot of paint on the LED.
Asking $90 OBO $75
- - Uniquefire 1504
Brass pill, machined to improve emission angle in flood mode, XP-L V6 3C on 16mm Noctigon, dedomed, MCPCB soldered directly to the pill.
BLF17DD direct drive driver, wire jumper on spring (4.5 amps measured at the tail)
Stock tailswitch
Measured Candelas: 225kcd
Measured Lumens in Pipe: 880 @ 30 seconds
Asking $75 OBO $70
- - Uniquefire UF-1405
Aluminum pill, machined for improved emission angle in flood mode, blackened with a sharpie, XM-L2 U2 3C on 16mm Noctigon, dedomed, Arctic Silver thermal adhesive used to mount MCPCB to the pill.
Copper tube used to increase driver mounting size, 5A driver from Mountain Electronics , 18ga jumper wire on spring
Stock tailswitch
Measured Candelas: 327kcd
Measured Lumens in Pipe: 935 @ 30 seconds
Asking$95 OBO- $85- SOLD
- - Jax Z1
XM-L2 U2 3C on Noctigon MCPCB, dedomed, MCPCB soldered directly to brass pill
Stock driver with 2xR330 resistors stacked on the sense resistor for approximately 4.5A to emitter, 18ga wires to LED, 18ga jumper on spring, silicone cubes added to driver cavity
18ga jumper on tailcap spring
Includes 1 extension tube
Measured Candelas: 152,924 (on 2x26650 batteries)
Measured Lumens In Pipe: 1215 @ 30 seconds
Originally asking $100+shipping, now$95 shipped- $80- *SOLD
- - Jax Z1
Red XP-E2 on Noctigon MCPCB, dedomed, MCPCB soldered directly to brass pill
Stock driver
Measured Candelas: 94,731
Measured Lumens In Pipe: 245 @ 30 seconds
Asking $95 OBO $85
- - Convoy S6
Triple XP-G2 S2 1D on Noctigon MCPCB, dedomed, MCPCB soldered directly to 20mm diameter x 12.5mm long solid brass spacer, brass spacer soldered to brass pill with higher temp silver bearing solder
Carclo 3UP Narrow spot optic, clear
BLF17DD driver, 4 modes with memory, wire jumper on driver spring, no jumper on tailcap spring to help manage current/heat
Measured Candelas: 16,240
Measured Lumens in Pipe: 1788 @ 30 seconds (on Efest Purple 2500mAh battery)
Asking $85 OBO
SOLD
- - Convoy S6
BLF17DD driver, 5 modes no memory starts on high, wire jumper on driver spring, jumper wire on tailcap spring
Measured Candelas: 16,290
Measured Lumens in Pipe: 1840 @ 30 seconds (on Efest Purple 2500mAh battery)
Asking $85 OBO $80
- - Cofly KX035
Q.lite Rev A Driver
Nyogel on O-rings
Measured Candelas: 28,690
Measured Lumens in Pipe: 813 @ 30 seconds
Asking $40 OBO $30
And finally a group shot. (I forgot to put the second S6 in this shot, but I swear the two look identical. :bigsmile: )
