Hi guys, I thought I would start a new thread instead of hijacking someone else review thread.
I have started modifying this genuine P7.2, its actually dead easy to customise, everywhere I have read on the net I have read says otherwise, once I have finished I will post some pics.
I have started with the button on the bottom, remove the battery carrier and through it in draw, I dismantle the tail assembly from a spare C8 i have here, removed the switch from it, then removed the rubber boot at the bottom of the LL tail, then got a small green plaster plug, cut it back to the right size to act as a plunger for the switch, the switch then firmly sits in the tail cap with its round mounting plate sitting flush with tail cap, then I have soldered the plat to the LL tail cap housing, and thats it, button actuates perfectly, the spring is still the on the mounting plate and the battery can sit perfectly on top.
So an unprotected 18650 will fit lengthwise but will need sleeving, I will order a 25500 after testing this mod as I think that will be a perfect fit, the driver is one of the easiest mods to do as its a simple swap out with any board you want, the only issue I have here is its
a 21.5 board and there doesn’t seem to be many choices in that department, if anyone has link to a nice driver to suit 1 x 18650 with lo-med-hi settings and a max output of say 1500 to 1750mah or even copper spacers to adapt 17mm boards to 21.5 I would most appreciate it.
I have found on Fasttechs site a XP-G2 R5 which will also be a simple swap out, I could go to an XM-L2 U3 but the bigger chip may effect the lens, so I will stick with the XP-G2’s I’m really after superior battery life rather than more performance.
If this mod all works out I will take photos and show a step by step incase anyone else is interested in having some fun with an over priced but very attractive little torch.
The other thing to add, is all these mods are reversible, the torch was easier to take apart than I first thought.
The Pills
P7.2
C8 Doner Driver
Tail Switch
22650 to 18650 adapter
All working
This just a proof of concept, I will neaten the whole thing up in the finished product ![]()
