I’ve been using a 3v 50.3 lately and thought I would try slicing the dome out of curiosity. Lowered the CCT from 5800 to 5000. The CRI went down (70 to 67) and the DUV went up (from 0.0021 to 0.0081).
It’s much less visually appealing now. More yellow/green. Oh well.
Indeed! I have a couple more on the way to retest. I’ll get picture this time around.
One thing I noticed while slicing the dome was the dome itself looked different than most emitter domes I’ve encountered. It almost had a refractive quality to it. Unfortunately it went flying across the shop into the abyss. Oh well. I’ll document it all with the next emitter I recieve.
I would absolutely love to see the pictures from your next test! Hopefully they will demonstrate the refractive quality you described.
The only negative dedome experience I've had was 3V XHP50.2, which turned green after dedome. It is not surprising to me because the phosphor pour is very different and extends way past the underlying blue chips, so any theory about dedoming a typical emitter (phosphor exactly over blue chip) goes out the window. Dicing it up (removing the excess phosphor past the blue chips) removed the green.
Your case surprises me because as far as I can tell, with the 3rd gen XHPs, the phosphor pour is exactly over the blue chips and does not extend beyond, so the phenomenon I described with the XHP50.2 should not be happening.
Maybe it would help if you remove the yellow phosphor around the die (‘slice and dice’). A minus green filter would help for sure but it also reduces the output. Glass lenses with green AR-coating are useful, too. Some 3V XHP50.2 really have a nasty green and swapping the led is also a good solution.
