Mosfet remote tail cap switch.
Been there, done that and have the T-Shirt.
I made these awhile back and they were for positive ground as PT54 as all other PT emitters. My tailcap either switch or tape activated were powered by a CR2016 coin cell. My PT120 thd fet was installed inside of the heatsink so I could access the negative pole and the coin cell was not needed. You can search CPF for a switch called a “FETtie”. I too am electronicly challenged but was able to reverse engineer his design into a spring loaded switch circuit board with a PETE plastic housing and a hot glue gun. For conventional negative ground switch a reverse mosfet from what I used maybe needed. More info is in a post on exact mosfet used.
