MTN Electronics: LEDs - Batteries - Lights - Chargers - Hosts - Drivers - Components - 1-Stop-US Source
Approximately 5.5 volts, which is the limitation of the MCU input voltage. The 70N02 is good for 20V source to drain, so 4S cells would be fine (and works fine with the zener version).
I have used this driver a lot in the 12 LED lights, with 3S cells on the input. I wired the leds 3S4P, matching the voltage requirements on the input and the output. I also use it in the BTU Shocker with 3S input and 3S output. I have even used the driver in a 36V application, but the 200 ohm resistor needs to be replaced with about a 1.5K-2K resistor, and the losses are quite high so a voltage regulator/buck regulator to supply the MCU would actually be much more efficient in those applications. (I wasn't concerned about the loss of efficiency).
I’m thinking you’d have to do a Zener modification to be able to run series cells to series LED’s in order to not fry the MCU. There is a BLF17DD Z board made for this.
I’m sure Wight or Richard or Comfy or someone can give you more info on that aspect. These were originally designed as a single emitter single cell direct driver replacement for the Qlite or Nanjg 105C style driver. There have been a lot of variations for the multiple uses people have come up with.
Thanks guys, that is what I needed to know. That is why I made the post, to say that this confirmation is not readily available upon a 1/2 day effort of searching.
I will update the driver listings with acceptable input voltage ranges.
Thanks!
Got in a huge shipment of LEDs and other parts yesterday and they up and going fast...too fast! Good thing I got in some more orders before the Chinese holiday, huh? If you're waiting for out of stock batteries too, they were supposed to arrive yesterday but should be arriving this afternoon, so if you need both just hang tight for a little bit so you can get them in a single order.
The Maxtoch M12 Mission and M24 Sniper are up. The machining and finish on these lights is as nice or nicer than any Fenix, Olight, Thrunite, or Nitecore I've seen. The M24 is super light!
Also, I am going to be moving to a better web hosting service in a week or so, so there may be a few hours of downtime during the switch over. It should bring faster and more reliable access to the site.
P.S. MT-G2 on 16mm Noctigon and a new 25mm MT-G2 Noctigon as well (with 4 individually addressable XQ-E pads on the outside!)
Any updates on offering the customized TrustFire TR-J20? IIRC you posted that everything else you looked at had severe thermal issues that made them unacceptable, at least to you.
I don't know if there is enough demand to make it a "stocked" custom light; however, I will build one for anybody who wants one. They can handle a lot more heat than anything else I've tried. In the mean time I have tried several different 12x lights...actually just about all of them I can get my hands on. Some are better than others, but none of them can handle a lot of amps without TONS of heat sag. I'm talking about sagging to 50% output in a matter of seconds, which just doesn't do it for me. On copper MCPCBs I'm sure that the sag would be less, but on most of the 12x lights with the stock aluminum MCPCBs you actually end up ahead in lumens after 30-60 seconds by running less current instead of more (more actually is less sometimes ). With the J20 I could push the emitters to 3A+ each on the aluminum MCPCBs and not worry about it. In the other lights you will absolutely fry the LEDs if you try this for more than a few seconds--the tell-tale visible blue tint shift and 50% drop in output with amps rising is a sure sign of that. On those lights I have been limiting output to around 1.5A per emitter and the result is better, but they still get too hot after 60-90 seconds. Regardless, they are still a lot of lumens for the money, but the J20 really is the optimum platform for huge 12x emitter power.
I just gave you my first order last night; just realized I could have use a coupon code. But the real reason I am posting is that I love your store. Site is easy to navigate. Good prices. Fair shipping. Thanks.
Richard;
Do you offer 18650 to 26650 adapter sleeves as a separate item. I need three for my new TR-S700 which did not include any.
I don't, but should probably pick some up. Up until recently I didn't have many 26650 lights except for the DQG Tiny Triple for a while, and it came with an adapter. Maybe ILLUMN has some? Otherwise you're going to a be a few weeks out due to the Chinese holiday.
Yeah I love my 15 led… But your right about the heat catching up to the body. I stuff a real copper scrubber in the head- it compacts down close to solid… Maybe fit 2 in if really wanted too the pill is that big. But that helps quite a bit with sag. You need to craft an oven mitt for it literally. But I love the flood it’s just exactly what I want in a flood lamp. The 5 led is nice because there are no heat issues, but it doesn’t come close to just spanking light all over the place :slight_smile:
My Amazon check and Google search indicate all are shipped from China with NO USA SOURCE available so you have a potential USA exclusive if you carry them and I would expect demand to increase as 26650 lights become more common.
You said you have experience with most all of them… I am looking at the tr-12t6 because of the 6 cell config. Is the shelf adequately thick? I’bm definitely going converting to noctigons and going BLFDD running the leds 2s6p off of 6 25Rs. Plans to mod to an e switch too to handle the power and be more ergonomic…
Jared, I don't have any experience with that particular light, but it looks like a good candidate! I think that an eswitch may be mandatory because of the 2S cells (tons of amps through the switch!) but a pretty sweet light.
The DQG Triple II came in yesterday, and I spent last night torture testing one to make sure it would hold up. The only thing left is to see if the switch is more water resistant than the old model. The switch is a completely different design now (no longer integral to the driver) so I think it has a chance of withstanding a some rain now. I will update you with the results.
I also have a few Jax Z1s. This is a pretty cool little zoomie with pretty nice performance, even stock at 3A to the emitter and an included 2x26650 extension. This is definitely the highest quality zoomie I've seen yet and I love the compact size when zoomed wide and 26650 capability. The obvious upgrade will be a dedomed XM-L2 or XP-G2 on a Noctigon, along with an FET driver for single cell use. I also have a stock driver turned up to 4A that is working but I need to torture test it for a while to see if it will hold up to extended use on high--this would be an increased power option for those who still want the option of running with 2x cells.
Look for them on the website this evening!
I will have to do a retake sometime, because the lighting is poor and I block the camera frequently, but this is a quick video describing how I add 7135 chips.
RMM, are tracking numbers usually provided automatically for orders placed on your website?
Great info there! Thank you for taking the time to do this.
I really want to build a flashlight from scratch and this is will be a great help so I can get there with less frustration.
Side note: Your headlamp is too bright for the camera, and that should be expected on every BLF video.
Yes they are. When your order ships you will receive one through PayPal and if you registered for an account it will also be available on the website.
