Was going to ask about a product here but I guess better to email MTN? Looks like the last post/reply from him here was back in September.
It doesn’t hurt to ask here as there are many folks very familiar with Richards products.
OK I also just emailed an inquiry…. If they will soon be stocking some XP-L2 5000K bare LED’s.
Okay, a question about his stock and reordering is something only he can answer. Lol. I thought you had a different type of question.
I don’t know if he’s even working this close to holidays.
Does anyone have information about how to activate moonlight mode for a 17mm FET driver (standard firmware)?
Specs say to solder pin #2 to ground. Is this referring to the pin on the fet or the microcontroller?
Also, will this affect the other modes?
What is the output for moonlight mode on a fet driver? I’m hoping to get my light down to < 1 lumen for reading in bed.
first post in over a month. Think of all the work Richard is able to get done without attending to this thread
Pin #2 on the attiny13a. There should be a little dot at pin 1.
Thanks for the info :+1:
Now I get to play the game called “Don’t bridge the pins”.
FET moon is … generally not very good. Usually bright and/or highly voltage-sensitive. The details depend on the exact hardware though, and which method is used to implement moon.
Yep that’s the one. Tried the bridge (pin 2 to ground) and ended up with 1 mode (high). I must have bridged pins 3 and 4 via the trace. Cleaned up the solder so that pins 3 and 4 aren’t bridged and ended up with 1 mode again but this time it was low mode. I must done something to the microcontroller by running voltage with pins 3 and 4 bridged. Here’s a pic of how it ended up. Everything looks good except it only has low now.
Is there any hope of recovering this driver?
I’m thinking that a FET + 7135 may be the way to go if moonlight mode is wanted.
Update: I got it to work! —> I removed the copper wire and soldered the pin with a “2” next to it to ground. Moonlight mode is now activated. Moon mode with this driver is not super-low (like firefly) but provides enough usable light to comfortably read books, maps etc in the dark without compromising night vision.
I have one of the FET+7135 on a triple mod and it has a very nice ML.
Thanks for the advice!
I’ll have to try that next.
I think I see the problem. The pin closest to the ground ring is marked with a 2 and has a tiny pad (on the right of your picture) bridge that to ground.
I think lion42 hit the nail on the head.
Mtn descriptions.
Clicky Pin Functions. Soldering these numbered pins to ground will enable these features:
2 enables moonlight mode.
3 reverses mode order from the standard ascending (low to high) to descending (high to low).
It does say pins, I had to go back and check.
It probably should have said Numbered pads (hint Richard).
Try gounding the number 2 pad to ground which would be pin 5.
Also if you want option 3 you would solder pin 3 to pin 4, 4 is already connected to ground.
So I just received a notification of activity on this thread today (February 28th) and it looks like the last activity was on January 30th....
I think I just need to start checking in here every day since it seems like notifications have been flaky lately.
Going forward I am going to label all of them by pin number; the old "Pin 5 = 2; Pin 3=3" nomenclature harkens back to the 105C/QLITE driver configuration "stars".
yeah, I got a bunch of notifications today but when I went to view them, none were current!
Glad it's not just me!
It was spam that got deleted
Bonus comment: give 17-22mm boost drivers.
It was spam that got deleted Bonus comment: give 17-22mm boost drivers.
I am still working on it. Had to get through the holiday rush...the 17mm is working well in my light, just need to make a few final tweaks then order boards.
