This is a improved multi-function base/stand for the BLF LT1 Mini Lantern. features include a hook for mounting on a guy line, mounting points for the mini’s bail, holes for attaching cord, a mount for a 18x3 mm neodymium magnet and a ¼-20 nut for mounting on a tripod. I also added slots for attaching the Mini’s lanyard.
Note that the base will mate with my diffuser for the LT1 Mini for storage and transport.
Both the ¼-20 nut and the 18x3 mm magnet fit very snug and normally do not require glue. Be careful installing the magnet to keep from damaging it. Once the magnet is installed, you probably won’t be able to remove it without damaging it or the print. If you want the magnet’s poles oriented a specific way, check before installing!
The 18x3 mm Magnet I used is the Magnet Source brand available at Home Depot.
The diffuser is designed to eliminate the dark spot caused by the stock diffuser when hanging inverted.
Warning - do not mount or hang lantern anywhere it might fall or come loose causing injury or property damage!
Base without hardware (no 1/4-20 nut, magnet, bail, lanyard etc.) - $6 Available in Black, white, dark blue, dark red, yellow and pink.
Base with Magnet and 1/4-20 nut installed (bail and lanyard not included) - $12
Diffuser without bail - $5 available colors - clear/white, red, green, orange.
Flat Rate Shipping anywhere in the USA - $6 per order.
Paypal goods and services. Please allow 2-3 weeks until these are printed and shipped.
If you have a 3D printer, these are up on Printables:
https://www.printables.com/model/322628-blf-lt1-mini-multi-function-base
https://www.printables.com/model/328650-blf-lt1-mini-diffuser
Thanks.
