I can make you a parts list for 22mm drivers for LCSC if you’d like. just confirm 22mm first
Yes, resistors are all 0603.
0603 for C2 cap
I use 0805 for OTC and C1 caps. On 17mm builds, 0603 for OTC cap.
It looks like they just went OOS on the Schottky Diodes though
ETA: Here is a DigiKey Cart for clicky builds, with notes for component placement. Choose ATtiny 25 or 85 in cart. Unfortunately, they do not carry 7135 chips
Yep. Good call. I think my first order was 150 as well
I think I got all the parts in the cart including the fet which is this one
And there are only 5 available the rest is on backorder (15 total). It’s the lowest hate voltage and rdson I could find at normal price. Got any othe suggestions? Also don’t know what Schottky to pick other than package.
Would this one work?
Man, I’m not too much help there, sorry. I’m still trying to get a grasp on all of this stuff myself.
I’m good at “clicking and ordering” then getting decent at the building part. ![]()
I’ve tried to find a suitable substitute for the Schotkky Diode that keeps going OOS on me, but don’t understand what would work.
When they came back in stock about 10 days ago, I said screw it and ordered 75 of them. LOL
Google says it will work, but I don’t know any better.
I will add the AOS AON6500 Fet is tried and tested to work well, and I’m unfamiliar with the one you posted.
Maybe @INeedMoreLumens can chime in.
See, that’s exactly why I wanted to start with those fet drivers from INeedMoreLumens ![]()
Hehe. I think the Schottky diode you posted looks like the best option, but I’m curious what the more knowledgeable people have to say.
@Toaster79 When you want an e-switch Anduril build, you should definitely do one of these…
I most definitely will as this was my initial plan for both fet and clicky, thats why I asked about the clicky fw.
Also the 32mm version would fit perfectly in my headlight. Although I designed it initially around the convoy driver I did a few minor changes so it can take a 32mm driver. The threads were 32x1.5mm at first which I changed to 33x1mm so the 32mm driver fits perfectly too
Gotcha.
If I were going to start all over again, I would use this for my Fet+1 clicky builds, IF I weren’t going to do a Texas Ace for some reason.
22mm Single-Sided FET Driver PCB - V1.3b - MTN-22DD
But I can’t find that board on OSH.
32mm version.
I have some of these boards on order from OSH.
I can’t get the datasheet to load on my phone
It’s SOD-323 so it will fit physically but the 3A is way overkill
What would the downside be of it being 3a?
Is this one the revers polarity protection or a ldo?
Reverse polarity protection the LDO is only required for 2S and above
Probably overkill but bullet proof ror a single cell ![]()
I can see the specs on there webpage but honestly they seem too good to be true so I wanted to verify the information on the datasheet.
I’ve found mistakes before.
