After seeing so much creative work from the modding community here, I was inspired to take my own crack at it!
Host: Massdrop sent me a Copper Tool AAA with a cool Cree emitter instead of a warmer Nichia emitter, so that seemed like a great candidate to mod.
Emitter: I ordered some LH351D 5000K emitters from Sofirn in the hopes of one day using them - today seemed like the day!
First step, removing the pill. Turns out the head of the light was pretty securely glued, and I spent a long time trying to force it out.
After attacking it with an array of pointy tools, I unscrewed it with the use of a strap wrench, a hair dryer, and needle-nose pliers filed to be pointy.
The decimated contacts bear testament to the abuse the head endured until it finally relented.
With the hardest part out of the way, I reflowed the LED without issue.
…Kidding, I overheated the PCB to the point of delamination, added too much solder, and dropped the whole thing several times. It took me many, many tries to center the emitter.
With the puckering of the board and excess solder around the LED, I was shocked I hadn’t somehow shorted it out.
(Also, the back of the PCB is smeared with solder from the soldering iron I heated the PCB with. I gave up trying to clean it off.)
But with everything put back together, you can’t tell how unsightly the innards are.
And with a stroke of luck (finally), the reflector fit perfectly around the LH351D, no centering ring needed.
Now for some beamshots (mostly just for peace of mind that I didn’t cook the LED to death during the reflow)!
Order from left to right: Sofirn SP10S (LH351D), Copper Tool AAA (LH351D), Sofirn SF14 V2.0 (Cree XP-G2)
The LH351D emitters are the same colour, and they look nicer than the XP-G2. Looks good to me!
Thanks for joining me on my first reflow adventure! And thanks to all the modders that gave me the confidence to try it.
I look forward to working more with electronics…but I think I need to improve my precision before I torture another emitter like this.
