So I got a few shots of my light in action, hope you enjoy them :)
PS-Since I'm new here I haven't made a topic showing the build process of my custom "LightCanon Flashlight" (misspelled on purpouse) but I'll get around to it in the future. For now, you get beamshots.
1) 950m distance, target is a radio antenna at the top of a mountain.
Day shot:
Night shot:
Zoomed in even though my camera is bad you can see that the antenna is well lit up, and the red dot is the signal light on the left antenna.
The ambient light could be simulated with a wireless flash, photographers trick
But you photos seem to be shot with something cheaper than my 550€ flash for DLSR
But if this is a normal 100W bulb the flashlight is impressive
Yeah I don’t use an expensive DSLR :C just a point and shoot, takes ok photos but horrible video.
Got any recommendations for low light camera to take videos with for $500 or less?
Also, what do you mean 100w bulb?
The street light to the left?
Aren’t those usually a lot more than 100W?
It’s a 100mm aspheric lens with a wavien collar over the LED.
The lens has a really long focal distance, so even though the wavien collar only lets 60 degrees of light out, there is still a ton that does not hit the lens.
I have blackout paper at home that I need to add to the inside of the light to block the spill from showing through the vents and PVC.
Is it good because it has a large sensor?
I’ll look into it, thanks
Fixed lens isn’t a problem for me.
Yeah, it really works, does about 150-200% improvement, unfortunately wavien has gone dark.
Anyone looking for collars now needs to get an electroformed reflector or something like that.
