I only paid $21.00 for this but have been pleasantly surprised by it! The first thing that struck me when I first saw and held it, was the finish on it. It looks like a way more expensive light. But that is not all! It has last mode memory, is USB-C rechargeable, has USB output connection for charging a cell phone, is regulated, has low voltage protection for the battery, anti-reverse connection protection, a glass lens, and all three brightness levels are well spaced. Levels are 960-495-66 lumens. It runs, and comes with a 21700 battery, and also came with a nice, braided USB-C cable with right angle connectors on each end, and a nice lanyard, and a diffuser! I like it so much I order two more lights of the same brand. The tint is a milky white and is a good thrower, but still has a nice spill. Here are some pics!
Nice looking, what brand is it? I looked up Tiooka and nothing came up.
I know! The brand is apparently Tiooka, but I also could not find any information about them. I have two more lights on the way by the same brand and I should get one today and one tomorrow. I hope they are made just like this one. I bought them off Amazon, and the only problem was the description of the lights in the posts. On the one I have received, the description seemed to describe three different lights. I do not think the seller is being very careful when posting information! ![]()
https://www.amazon.com/Tactical-Flashlight-Zoomable-Waterproof-Emergency/dp/B08TBFJM73/ref=sr_1_85?keywords=Tiooka&qid=1639925145&sr=8-85
The description is a mess…
It is! The light you get is the one which has the description on the box in the photo. They have a 26650 version of the light that I should have tomorrow. At least they are not advertising it as a jillion lumens!
The lumen ratings, at least on the light I have, I think is spot on! I also kept in mind when I ordered it that Amazon has a great return policy.
Does it run off of AAA or 18650 battery?
Heck, they mention 21700 and 26650 as well.
That description is a mess!
It runs off of a 21700 battery and comes with one. You can also use a 18650. I guess if you had an adapter, it would run off of 3AAA’s, but that would be a real weak power source and would probably not run very long. Again, look at the photo of the box the light comes in. That is the true description of the light.
How do you like it so far mikeoz?
So far so good! I received two more lights of the same brand, and one is a larger version of this light. It uses a 26650 cell and puts out about 1919 lumens according to the box it came in. I also got an even larger light that uses 2 26650 batteries stuck together in parallel. That one seems to have an odd issue and I have contacted the seller. Maybe tomorrow I will post a few pics!
