There have been many methods for this, gluing on rings, rubber pads, or line up a pocket clip, I recently came up with this idea (although probably not the first) and it works great!
It’s sold under many different names: Anti-skid tape, Safety tape, Grip tape, Skateboard tape (you get the idea)
I’m using the very aggressive “mineral based” stuff. (sandpaper grit texture) A small pad of this goes a long way for locating a side switch in the dark.
Another option (photo below) is to place a small pad or strip below/near/around the switch.
For the TC20 I originally I did this so it wouldn’t cover the indicator light, but I made the pad too wide and it was less accurate to find the switch.
I ended up making a “donut” ring using the paper punch and a leather punch for the smaller hole. (see photo above)
Only on the Jetbeam E20R did I think that, just because that switch is so large flat and smooth, however for those same reasons it seems harder to locate in the dark.
I don’t put it on certain lights that I use for work and I can see the switch, only for lights that I’ll need in total darkness,
If someone needs to retain the smooth feel of their switch they can apply a small strip or pad directly under the switch (like I did on the TC20) or maybe on either side around it, that works great as well.
But in general the benefits outweigh the disadvantages, To me one of the worst things about side switches is rolling a light around in my hand trying to feel for the switch in the dark.
Reminds me of something I just read on a medication info sheet: “your doctor has prescribed this medication because he or she has judged that the benefit to you is greater than the risk of side effects”
Pretty much all tail switches on flashlights have a textured rubber boot.
Almost all flashlights have knurling on them somewhere.
Why would some texture on the switch be any different?
It helps find the switch, which is why flashlights have ridges or texture on/around the switch already.
What does this have to do with tail switch lights?
Regardless of whether you believe it or not, this stuff is a MAJOR difference from ANY knurling, maybe you’re thinking of the smoother texture tape? I’m using the VERY aggressive type of tape (mineral based, like sharp grains of sand) It’s a great resolve for locating a side switch in the dark. For me it totally corrects an unpleasant experience.
But of course it’s not for everyone, obviously you’ve never had any problems locating a side switch because the existing “ridges or texture on/around the switch” are working for you, It’s great that you’ve never experienced the issue, so no worries.
Yeah, I think he was responding to me asking about the rough button. The difference I see between the button being rough versus knurling or “rough” rubber boots, is that a sandpaper finish might actually wear out your skin a little when you press on it. The rubber boot won’t do that, and the knurling isn’t meant to be pressed on anyway, so those aren’t comparable. But, anyway, if the stuff works without bothering you, I’m okay with that. It was just a curiosity for me. O:)
Looks like he’s saying it’s not textured enough…that placing “some texture on the switch” is no different than the knurling that almost all flashlights already have…
And he goes on to say the grip tape pad isn’t necessary because “flashlights already have ridges or texture on/around the switch, to help find it”
Enderman may have never experienced the problem or read anyone’s complaints about it, but know I’m not the only one who has, I’ve read many posts about the issue with locating side switches.
One thing I can say for sure, with this method I can spin a light around in my hand between my fingers feeling all of those existing knurling, ridges textures etc. but when your thumb or finger makes even the slightest contact with this tape, you’ll know it immediately!
beam0, I like that you found a grippy tape that helps you.
At first I took Enderman the way you did, but after reading chadvone and rereading the quote in Endermans post, it sounds like hes supporting your rough patch idea, not contradicting it.
As DavidEF suggested, focus on the comment Enderman quoted and was replying to:
His [not quoted] language structure before that statement, created a misunderstanding, for you and I both, at first :-).
I’ve come to the conclusion that Enderman didn’t realize the type of grit tape I used, most of his statements do make sense for the smoother grip tape they use on pistol grips etc.
It’s actually a good thing he commented on it because it caused me to further explain in detail the exact type of tape I used. In hindsight I realized there are (far) less aggressive tapes out there that are fairly common and pretty much would have no effect.
Yes it feels something like that when you feel it to locate, but in actual pressing using the button you don’t really feel it that much.
For me it’s an awesome fix for my issues finding side switches in darkness. Also look at the photo of my TC20, the grip pad isn’t even on the switch, and it works wonders for a switch locator!
The tape I used is the very aggressive type, similar to medium coarse sandpaper.
……Here’s the tape I used, had it left over from other projects: …………………………………This may be very similar, I’ll check it at Lowe’s next time if they have it.
This is a pretty cool idea. :THUMBS-UP:
I have a Astrolux E01 that was extremely hard to find the button just by feel. I got so annoyed I made a taller switch button and installed a trit vial. Problem solved but this could have fixed the problem with a lot less work. I would probably have went with a little finer grit for my personal touch.
